'69 Scout Question
Reeeeeeeeal funny, Eric. By the way, you're really showing your Postal A** there... :p
Travis
At least it's a nice-looking rear!
Can't you find something on these on google?
I found this as a description for a single diff cover:
Jeep rear CJ 1941 to 1975 - Ford front 1966 to 1979 F250 & F350 - Ford Bronco front 1971 to 1979 also f100 & f150 - Dodge front 1972 to 1978 Ramcharger & Pickup - Jeep front 1974 to 1986 Truck, Wagoneer & Cherokee - Jeep rear 1974 to 1980 - IH Scout front 1975 to 1980 - IH Scout rear 1967 to 1980 10 Bolt - Dana 44 DO NOT USE ON GM FRONT
Looks like a D44 to me....
Thanks, BW! I never thought to Google.... don't use that too often... :o I'll give her a whirl......
scouts
Dana 44 good swap into a scrambler available in the ratios of 3.31 3.73 4.27 optional powrlok diff
the "scoutconnection.com", says:
6. How can I tell what axles my Scout has?
Dana 30 front axles and Dana 44 rear axles were standard on the Scout II's, up until 1974. You could special order a Dana 44 front axle for a Scout II in 1974.
In 1974 and later, the Dana 44, front and rear axles were standard in the Scout II's.
If you are not sure which you have, you can compare axle covers. If they look the same, front to rear, they are probably both Dana 44's. If the front cover is a smaller, rounder cover, it is probably a Dana 30.
