the "scoutconnection.com", says:
6. How can I tell what axles my Scout has?
Dana 30 front axles and Dana 44 rear axles were standard on the Scout II's, up until 1974. You could special order a Dana 44 front axle for a Scout II in 1974.
In 1974 and later, the Dana 44, front and rear axles were standard in the Scout II's.
If you are not sure which you have, you can compare axle covers. If they look the same, front to rear, they are probably both Dana 44's. If the front cover is a smaller, rounder cover, it is probably a Dana 30.
