My eyes suck.
Dain
I was just showing where to look !
If I put wide track axels that were geared at 4.10, how much would that change the gearing, i.e. would I notice it immediately would it feel like a big change or just a slight difference? I only ask because I l would consider WT's but like how it is geared now but would consider a slightly shorter gear.
Hmm wonder where I can get those 7.17 gears from that the chart has..
Sent from my SPH-L900
You could also consider buying factory 15X 8 wheels that would have the correct backspacing to eliminate the rub and also give you an extra inch of width on each side. Two birds one stone, 5 lug nuts.
Have you tried this before? I have an '81 with narrow axles and have considered wheel spacers but then it would offset the open ended center caps on the front wheels. Switching axels for wide trac is an option too but if the 15x8 definitely works then I'll wait patiently until I come across a nice set.
No, I have wide track axles with 15X7. But if you look at a 15X8 the depth or dish is noticeably deeper. I would conclude that this gives a wider stance. Several folks are running these rims maybe someone can chime in with additional details.
One more thing. I think the OP is running steelies that appear to have no dish. Maybe different from what you running.
