My .02...
I've owned 8274s most of my jeeping life and have never regretted it. They are, in my humble opinion, the finest Jeep winch ever designed.
That being said I can understand your question about need versus greed.
If you never use it and it just sits in the garage then why have it...? Well, that makes for a difficult decision and one that only you can solve. If you think you ill never go anywhere or be in foul weather that it may prove its worth then it would be silly to add its weight to the jeep. All it is at that point is a visual icon that robs economy. But I have found it amazing how having one on my jeep has proved useful in the strangest times. I've helped people get their cars unstuck off of a curb when they missed their turn and ended up blocking traffic due to hi-centering. I've used it to gain access to a passenger in a car accident so they could escape. I've also used it for things like straightening metal while working in the garage (and not having any other way to do it) as well as helping erect roof trusses on a friends garage.
Could I have done all this with a less robust winch or even a come-along? Maybe...some of it anyways. But it would have taken longer and required more effort.
I can't say if you should sell yours or not...that will be your decision. But if it helps, I have always bought mine used off CL (except a couple that came with the Jeep originally) and have paid as much as 650 and as little as 200 bucks. A lot depends on the condition of the winch/cable/electrics/control/etc... and if the buyer or seller knows what it is. Since these things are so expensive new (12-1600 bucks!!) I would never be able to afford one that way. And since they are so often not used by the owner they usually are only cosmetically "used". Plus they are fully rebuildable and basically will last a lifetime. So if I come across one for sale and it looks complete and is cheap enough i will often scoop it up. Just keep it on the shelf until I find a new Jeep for it.
One last thought is maybe you could look into a receiver style mount to allow you to keep it in the garage until you wish to mount it. Warn may sell one or any fab shop should be able to make one easy enough. Just have the female parts mounted on your jeep and slide the cradle in when you think you'll need it. They make great electrical connectors that have disconnects like those on electric forklifts..you just plug and play, so to speak.
Good luck wit your decision...FWIW I've always regretted each time I've "lost" one....
