8274 or something else
trust
PITA
White Rock
NM
I have an older but fresh 8274 which I remove and install depending on the jeeps use, off around town and dd, then on for jeep trips. I've owned this one about 8 years and the previous one maybe 10 on my cj5, I've used them combined maybe twice for myself and half dozen times for others plus another half dozen times around the house. Lately I wonder why I really need it taking up space in my garage but I know that If I sell it I wont be getting another one, even used they are likely out of my range nowadays. But do I really need one? I know I dont want to sell it, buy a $300 winch and have it not work, or buy no winch and go back to the come along and highlift arrangement but do I really need an 8274? How about an M6000 on a multimount? or????
I dont do hairy stuff anymore, mostly touring and longer point to point trips which can get surprisingly hard but generally dont
Thoughts? what does a nice used 8274 go for these days anyway?
thanks for the input
My .02...
I've owned 8274s most of my jeeping life and have never regretted it. They are, in my humble opinion, the finest Jeep winch ever designed.
That being said I can understand your question about need versus greed. :) If you never use it and it just sits in the garage then why have it...? Well, that makes for a difficult decision and one that only you can solve. If you think you ill never go anywhere or be in foul weather that it may prove its worth then it would be silly to add its weight to the jeep. All it is at that point is a visual icon that robs economy. But I have found it amazing how having one on my jeep has proved useful in the strangest times. I've helped people get their cars unstuck off of a curb when they missed their turn and ended up blocking traffic due to hi-centering. I've used it to gain access to a passenger in a car accident so they could escape. I've also used it for things like straightening metal while working in the garage (and not having any other way to do it) as well as helping erect roof trusses on a friends garage.
Could I have done all this with a less robust winch or even a come-along? Maybe...some of it anyways. But it would have taken longer and required more effort.:shrug:
I can't say if you should sell yours or not...that will be your decision. But if it helps, I have always bought mine used off CL (except a couple that came with the Jeep originally) and have paid as much as 650 and as little as 200 bucks. A lot depends on the condition of the winch/cable/electrics/control/etc... and if the buyer or seller knows what it is. Since these things are so expensive new (12-1600 bucks!!) I would never be able to afford one that way. And since they are so often not used by the owner they usually are only cosmetically "used". Plus they are fully rebuildable and basically will last a lifetime. So if I come across one for sale and it looks complete and is cheap enough i will often scoop it up. Just keep it on the shelf until I find a new Jeep for it. :crazy:
One last thought is maybe you could look into a receiver style mount to allow you to keep it in the garage until you wish to mount it. Warn may sell one or any fab shop should be able to make one easy enough. Just have the female parts mounted on your jeep and slide the cradle in when you think you'll need it. They make great electrical connectors that have disconnects like those on electric forklifts..you just plug and play, so to speak.
Good luck wit your decision...FWIW I've always regretted each time I've "lost" one.... :)
Personally I like the Multi-Mount Idea. It can stay in the garage out of the weather and away from thieves. I would put something like a Warn 8000, or their Tabor version on the sled.
Now the issue is that you already have the 8274. You could probably get close to the cost by trading but what would you gain. Maybe making it easier to put on and off, but not that much and in the end probably more $'s.
The one big advantage of the sled is that you can wire it up to work off of the rear of the Jeep. And it would be possible to swap to any other vehicle that you own. Or int he case of an emergency go and put it onto another vehicle and just run a set of extra long wires to their battery.
If you think that is a possibility then you might think seriously about using the sled idea. Otherwise you might just want to keep it safe in the garage and use it when you need too.
Just remember that there are times that you need at least one winch how and do not get below that point.
Carl
IMHO, the advantages to an 8274 are line speed, external brake(drum doesn't heat up-easier on synthetic line), robust construction, and iconic styling.
But, they're bulky and don't mount as "slick" as a winch like the M9000i. Because of this I personally don't think they are as functional on a removable mount.
I have an 8274, a 9000i, and a humvee winch sitting in my garage. I'm planning on front and rear winches. And still haven't decided which one goes up front. (I'm leaning towards the 9000i right now...) But I'll keep whatever I don't use, they don't take up too much space, and you can never find a cheap one when you need it.
Why not mount it up and leave it on. I cannot believe the additional couple hundred pounds can make a significant measurable difference in gas mileage. You can tackweld the bolts to make it very difficult to steal if that is a concern, or install synthetic cable to reduce weight.
The warn 8274 is one of the most rugged and dependable winches ever made. My son buried my blazer in a local river and i made over 50 full stall pulls to free it (along with 10 hours of digging). The blazer had a 12000 lb Tension and his riding buddies had Ramsey 9000 lb both winches motors burned up
I use to trail ride by myself back in the past and having a dependable winch added a lot to my independence and ability to enjoy a long trail ride.
Used 8274's in my area sell in the $450 range
Thanks for the input guys, I'm not so much worried about theft, I am fortunate to live in a pretty safe community and the thing is so heavy and well secured when mounted that someone who hasnt taken it off before would spend way more time than they would want to risk. I havent done any sort of quantifiable analysis of mileage or responsiveness associated with and without the winch mounted, engine temp is unaffected, just an assumption that i'd see an improvement. Sounds like the price range is about what I paid for it 10 years ago so I'm not getting bills paid by selling it.
I've thought about the multi mount, I'd only need to add a stinger and maybe some bracing to make that work, but then it's either transport in place or secure it in the bed plus the weight to deal with, but I do like the idea of being able to move it fore and aft as necessary.
Talking it out and reading y'all's responses have made it clear to me though that I'm not gaining anything by selling the one I have and replacing it with something else, at least nothing beyond some weight savings up front.
Thanks for restoring what passes for sanity around here
