'83 4.2 258 vapor locking
ChasP CJ8 83
New member
Houston
TX
Having driven off and on thru the day with no stop and restart issues - Hot afternoons after driving 30 min +/- engine compartment gets extremely hot and shut off engine for 15min. will not start until some cool down. Sounds like no fuel to the carb. I thought "Vapor Lock" issues went away in the early 60's at the latest. Couple shots starter fluid and were back running. Hood is still to hot to touch without gloves. Anybody know how to fix this? Planning to reroute fuel lines to get them away from the block and insulate better in hopes to help prevent! ????
What does your temp gauge say, assuming it works? If your timing is advanced too much, it will cause your engine too run hot and will lack power.
Planning to verify timing today. As for Temp gauge working. What is that? Didn't know they were supposed to work. Haven't had a jeep yet with a reliable temp gauge in the cluster. However, engine has never gotten hot enough to boil over but the hood prop is hot enough to blister your hand. Does feel like power may be weak so timing may be the primary cause. Thanks for the feedback.
Sounds silly, but put a wooden clothespin on your fuel line. Mr. Beep/Toby on here absolutely swears by this...
It does ! Ok I'll bite. Where on the fuel line ? On the metal tube or rubber hose ? Before or after the filter ?
right where it crossed over the valve cover. It acts as a heat sink. I've done this on various vehicles over the years. It WORKS!
No photo yet but it "WAS" a stainless steel line from the passenger side fender well wall where the where the duel out fuel filter is located, both main fuel and vapor lines ran down under the AC Compressor and Alternator over to the engine block, up the left side of the block (facing rear) where it was bolted to the block with two clamp type holders then up an over the top of the valve cover, barely missing the PCV valve back down to the top of the intake manifold to a nasty double "S" curve stainless tube to the carb fitting all spliced in places with rubber fuel hose couplings.
Now all that's about to be gone, but in the process discovered a crack in a stainless line and a crack in the brass fitting to the carburetor with the needle valve in it. Guess that's why it took a while for fuel to pump to the carburetor after sitting over night. Back for parts tomorrow!!
Yep, Duel Outlet Fuel Filter. Part of the Emission Control Crap !!
Attached a Picture and a cut from the Chilton Manual.
  • IMG_0279.pdf
    IMG_0279.pdf
Not saying this is an answer to your problem... but, the filter should be located just before the carb with the return port at 12 o'clock position.
This is noted in the Chilton attachment you added ,as well as the FSM.
The current setup you have sounds like potential for problems.
Just my :twocents:
Edit:
Just saw, looks like Errick is on it.:thumbsup:
Wow! My filter is on the opposite side of the engine compartment from the carburetor and mounted on the fenderwell just above the solenoid. Nowhere near the Carb!! However the line returning to tank is at twelve o clock.
They were at 9:00 and 3:00 until a couple days ago. You have a picture of where yours is?
Here are some pics of my '83 258 that's still in the frame.
The fuel line leaves the fuel pump and crosses over the valve cover.
The line changes to rubber line that feeds the filter.
The upper port is the return line to the tank, the lower goes to the carb.
I have also heard that the return port is on top to allow any vaporization of the fuel caused by the heat off the engine to be carried to the fuel tank rather than to the carb.
If this is correct, then your filter on the fender wouldn't really help with this as it passes by the engine heat after the filter. :shrug:
There are much prettier pics of other Jeep engines online. :(
Here is an overview of mine- what I believe to be pretty close to stock routing. My hood gets hot enough to fry an egg (working on figuring that out), but no vapor lock.View attachment 64412
This is how my old completely stock 46,000 mile '85 CJ7 had its fuel line run also.
Now that's a clean Engine Compartment. Going to have to work on mine after that!!
(while I'm relocating the fuel filter) Thanks for the Pics and Info Guys !! Great Help !!Pics
