Adventures with Peggy's jeep.
Well, I thought the trimming was going to be sufficient. It wasn’t even close. I went on its first wheeling trip and rubbed nearly everywhere in the front.
Decided to order these. Metal cloak CJ fenders.
Switched up my normal paint and used a hammered black top coat. Pretty happy with how they look.E0008D09-A9C2-4D54-83CC-11F8D4366108.jpeg
Tires stick out a bit as expected. It’s fairly wide.
The main reason I chose these fenders was the included aluminum inner fenders. I needed quite a bit more space than stock inner fenders what would have provided.
It looks pretty different, but I am happy overall. I think I could get 37s to rub. I think the real issue is my 3.5” backspace wheels. I will go to 4-4.5” before I would get bigger tires.FCAB3C27-E2B6-4203-B8A5-7A5EC9E2D8D3.jpeg
It’s more $$, but if you want more coverage you can get the Metalcloak flares that bolt to those fenders. They make a 4” and a 6”. They bolt on and off easily. Sorta hard to see in these pics, these are the 6”61B15369-062D-4620-90B4-7E73DD3BB196.jpegDA2DC351-055C-4442-BE90-CA7CE179A4EB.jpeg
These were just the pictures I was thinking of. Did you add the vents on the fenders? I have been debating between 4" and 6". I have about 9" of tire stick out on each corner so 6" would probably be more appropriate. Decisions, decisions... and of course more money to spend.
I added the vents myself. Used a holesaw for the corners and a jigsaw for the straight cuts. Dressed the edges until I was happy. I had a piece of perforated stainless, so I welded 3 studs to the backside of the fender to hold the triangular pieces.
The Metal Cloak CTI ramp made a stop in town. Decided to see what my setup would score. Didn’t really know what to expect, but it scored a 650. Pretty good especially when compared to JKLURs and even the JLUR.
I seem to have pretty good clearance in the front now. Surprised at how close the rear is to rubbing. 37s would require additional trimming.
Then I sold some stuff and am starting to look at PSC steering….
I swapped to an offset tie rod end to help with my ongoing steering clearance issue. The steering has definitely been the biggest issue I’ve had on the whole build.
This looks to have really improved my clearance issues. I won’t say solved, but it’s good enough until I make more changes.
Time to catch up. Just got back from a trip to the Ouray, Silverton and Telluride area. A few days before the trip my trusty tow rig broke down. So it got a trip to the shop. Apparently the internal trans harness was leaking. Super fun.
Of course it didn’t get fixed in time so I borrowed my friends 1500. Which then broke in Ouray which doesn’t have any real services. Newer trucks have electric power steering which apparently breaks often.
Maybe I’m a Ford guy after all and didn’t know it. We towed the backup rig from Ouray to Durango then I limped home without power steering. This was nice as I didn’t have to drive the truck on the million dollar highway as it was. I’ve always had good luck on long trips. Apparently I was due for some drama.
We ran quite a few of the trails in the area and had a great time. Jeep ran great the whole time, just a little less power at 13000 ft!
After dropping the truck off in Durango, we took the 8 from Ouray to load on the trailer. I normally don’t think too much about the work I have done. It did make me nervous a couple times on that drive to think that I have personally tightened every brake, steering, suspension and driveline fastener. So glad I have the 8. All of our gear and family fits!
Day 1 of the trip. We ran Imogene from the Ouray side as the three bridges were being replaced on the Telluride side. Certainly not a technically difficult drive. Most of this end of the trail is pretty easy to pass opposing traffic. Went from 7800 ft in Ouray to over 13000 at the top of the pass. Surprisingly enough the old tbi 4.3 seemed almost as happy there as it did at the base.
353ACA2C-8C40-4CE3-A5BC-922B72108313.jpeg422CC85E-A3F4-40F2-A94D-DC9F0D87B051.jpegA8BB4789-F20D-4987-9BBD-C968D8CDF4D1.jpeg7BA9F3AD-521F-48B1-9CA8-082D06D262A2.jpeg435175BC-0434-4FE8-B6B1-8092BFCB4F32.jpeg81841CBD-AC64-4026-A7B8-4B25AF60B5C0.jpeg0E6E348F-B61F-4A46-9B21-620607F2B77F.jpegE0475A53-26F7-456B-A74B-51C058B1E632.jpeg9B696538-1ADA-4ADF-9B61-7F5E04D3D256.jpegEF02DD16-AAFC-414D-89B2-5B86AAC6BF55.jpeg
I don’t really know why, but Black Bear Pass has always called out to me. I’ve wanted to run it for years. I’ve found that talking and dreaming about wanting to do something doesn’t get you there. Blocking the time out and booking a place to stay does.
The morning before running BBP we had a visitor. Kinda neat to see, annoying to clean the trash up every morning.000D0CDA-A1C7-4044-A9CF-C17764EE8E4E.jpeg
Started the morning in Ouray then drove the Million Dollar Highway to the trailhead.
From what I’ve heard the wildflowers really popping this year. Beautiful scenery.
53ECF958-49DB-4614-8C74-3004C0BFD4A1.jpeg37711C17-0E3A-4901-BB86-C7F4EBF9A25F.jpeg945EC09A-54F3-41C2-8268-86CA2ACFD272.jpeg0F42A425-9217-4FBA-9CD2-70FFCD4F04F2.jpeg
Nearly 13000 ft at the top of the pass.
Just as beautiful on the way down.
AEE12A87-8919-470E-BF96-FFD5A56FDAE3.jpeg706EA6F4-049A-4968-8243-1776EACECA4C.jpeg352C6D4C-CF9B-4E10-8CD8-2FFD304F161C.jpeg
On the way down my main concern was the steps. I spent way too much time being worried about that. I accidentally drove over the first set of steps without knowing it.
DDD25A22-3B36-452D-82CF-D94351FC30A5.jpegBA00893F-8C53-4965-AD45-4E7F664CD555.jpeg5902B2B1-C12F-4AE9-A23E-48B51F5624DF.jpeg
First set of steps. Probably worse than pictures show but not bad other than being off camber.
Second set of steps. If not paying attention you may be able to get yourself in trouble. Especially in a rig with IFS. I likely took the most difficult line. C19DA9A1-CA80-4362-AC15-FB6738ABD3C3.jpegCDF6D995-7FB7-4FFE-9E86-387081A4BEE6.jpeg
I feel that the scariest point is the narrow right turn after the steps. Very narrow and rocky. 813F84B5-C198-4775-8BE7-2B87B30BA53B.jpegEE7A2B5D-F550-4AE2-A05E-E4E7F0947B45.jpegD3C25A98-5999-48A0-AAA8-9003489847E1.jpeg
Then had to take the obligatory waterfall picture.
The first portion of the shelf road after the waterfall was the narrowest. 29192BB4-C0A5-4758-8A16-A4E0748473F5.jpeg03DE92D7-1237-43D3-A041-FDBCDAF3713C.jpeg
The first switchback looks pretty crazy when approaching. I only needed to reposition once going around.
1D701D53-E06D-47DC-B82B-FA10E4964FD9.jpeg7B04C3A5-5673-455D-A788-45D93903D903.jpeg3AD725F4-2B5D-4750-A99A-F262EB458E32.jpeg69B68C7F-56CE-4091-93D2-C984C83C59D3.jpegAB2D6D38-C518-45C6-A9E9-EBEA8CDD46DF.jpeg737C266A-DFF0-4367-85EC-CA480A4642C0.jpeg
Bridal veil falls. Really cool reference point as you start out a couple thousand feet above it then end up 1000’ below it at the end of the trail.A11E7FA8-3141-48FE-9B35-9D97547A66DE.jpeg
After this is just a bunch more switchbacks heading into telluride. We had lunch then ran Imogene to Tomboy where it was closed. San Miguel County was finishing up on replacement bridges and needed to plow the snow off the last section. Sadly we missed being able to be the first to run the full trail by about an hour.
I’ve never liked heights myself. Took a day or so in the area to get numb to the drop offs. So many places to die if you fell off.
After heading back down Imogene we went though Telluride for a splash of gas. Then looped around to Ophir pass. Ophir would be a good warm up trail. Mostly gravel roads and much less danger than the other trails we ran.
85A481E2-22B3-4F4E-B565-237A0FE3EA53.jpegD81B2023-8359-4BA5-8B02-CC5DDD71D1D8.jpeg3B87754D-7017-448B-95E9-C944B20EAD59.jpeg1443D0B5-8B99-4152-AF92-EACC230694D3.jpeg3EED5ADE-DACA-4895-BC83-5CCE4CDDCBA7.jpegB49E2C47-92A5-460A-8DC9-A224B9A30CFF.jpegACE9D2C4-4039-471D-8348-B7F108347110.jpeg809F52B1-6495-497C-ADD4-045F6F6B891F.jpeg71422644-92C6-406C-9E1C-14C6B69825DD.jpegFCA419ED-2F71-4F2D-AF7F-C63095A4B468.jpeg
After this we ran to Silverton to the funnel cake factory. They were nice enough to serve us even though we arrived 10 minutes after closing. Had our snack then headed up the million dollar highway to Ouray for the night.
Next day was the last day for running trails. On the menu was mineral creek/lower engineer to Poughkeepsie Gulch then over California Pass to Animas Forks then as much of Engineer as we could get before heading back to Ouray. Honestly the above is too much for one day if you are trying to enjoy the scenery.
Mineral creek was unexpectedly sketchy/scary. I think it had the most vertical drop of the trip. It was a reasonably wide trail, just so far down. After a short distance the valley flattens out and is like this to the turn to Poughkeepsie.
6D332E77-DE43-4FF2-AAB6-D1D4FD03EFDB.jpeg8C2E38F3-1292-4A35-9360-70BD22C899A1.jpeg6CEC1788-33EF-4FB3-8269-2C907F40A0A7.jpeg220C52AF-6BAF-4DDA-849D-052F2EE8CD46.jpegED972140-7EDA-45B4-B69F-D563214FE48A.jpeg10221427-0742-45AC-9270-BD8A437CA1E6.jpeg4F553259-5D5D-4775-91F8-05BF497482BA.jpeg0DD76C6F-7C6B-4595-B842-B571D7CADF1B.jpegEDA7C0E3-941B-49CD-81BC-FC5D6427DDBA.jpegC70CB257-B123-458D-A55A-5688896D81BF.jpeg
