after a long, hard trip from AK..
revho
$9.00 vanilla malt
beaverdam
postal update new pics on page 3 - 7/12/09
the auto carrier dropped this off late this afternoon. a little more body work needed than what we thought it was gonna be... but still a solid investment.
phone pic to start, will take more pics this weekend.
PICS IN POST BELOW
Sweet. :cool: I obviously didn't make it out last night to check it out. I'd like to see it on Saturday. Maybe I'll swing out sometime between 1:00pm and 3:00pm (Maeve's nap time). Will you be around?
Craig
hey craig, we will be watching the mich/wisc football game @ noon in jenison. not really sure what is going on after that, but we will give you a call. we will be out of the house this evening as well.
Clean
Well it sure looks clean from the pic. I am sure there is more to it, But good from far.
wow, I want details on what bodywork is needed... :eek:
I want the real pics too :D lots and lots of them.
Paraphrasing from Craig "This is a NICE Scrambler. The underside of the tub has essentially no surface rust (just the driver floorpan has been patched). The frame is super solid, too. The rust it does have is minor. All in all, it was a great purchase. BTW, he even let me drive it around his property...very weird with the RHD."
Craig
hope you dont mind me quoting you Craig, but your the expert (he was underneath it on a car creeper).
please chime in Craig, the rear door bottom corner and bottom seam of the door needs repair. behind both wheel wells needs repair, and the drivers floor. both rear body pucks are missing but both nuts are still intact, and its missing a bolt in another body mount. windsheild channel has surface rust, and bottom of the grill. all the door seals are very leaky. last but not least is the 3"x6" hole cut underneath the jeep logo on the drivers side of the tub.
pics will come probably this weekend.
Yes, I was extremely excited as I was rolling underneath Kevin's new Postal (Kara noticed my excitement, too). The trickiest part IMO will be the rear wheel opening lips (rear lower portion), due to the shape of the factory stamping. Kevin mentioned having a pro body guy do the work, so I'm sure it isn't a big deal. The cutout under the Jeep logo is straight sheetmetal, and should be an easy fix. For a nice resto-mod job, I'd probably look at a driver floorpan from Classic Enterprises (classicent.com). Omix-Ada probably has something available, too.
The missing rear body mounts are due to the fact that a previous owner replaced the rear crossmember with a piece of H.D. angle iron. It was a nice job, and included some integrated tubing that wraps under the rear corners of the tub to protect them. However, the rear end is just kind of "hanging" there, so some sort of body mount should be welded to the existing rear crossmember.
As Kevin mentioned, the underside of the tub is 98%+ black...almost no surface rust. The frame is equally nice. I expected that it would be a little crusty on the underside.
It's in notably better shape than I expected, which makes it an even better deal!
Craig
Every time I look at my frame, I'm impressed with whatever undercoating that they put all over it... to this day it's still almost entirely very nice and pliable and very tenacious.
I don't think that many of the roads these things saw were salted, so that goes a LONG way to keeping things in decent shape.
Great to hear about the condition, now about those pictures.... ;)
revho said:
I just noticed your side view mirror on the passenger side... that's not the one that came on the Postals, the large frame held a very tall (12"+) vertical rectangular mirror, not the stock CJ mirror.
I have the one that was on mine when I got it. I swapped over completely to the CJ style, removing the frame entirely (reminds me that I need to treat/fill those screw holes still :eek:) Would you be interested in it?
You can see it (very dirty) in this shot:
Don't you mean "driver's side"?! ;)
Yes More pics, too!!!
Congrats, nice finds!
pics
here we go
1984 alaskan postal (rhd)
4" suspension
some kinda shackles
mildly built 258
some 31's
the worst rust to deal with, bottom of the rear corner of door
info sticker with build date
more
s'more
floor
underside floor
driverside patch
driverside seat mount crack in floor
rear/under tub bumper with receiver
wheel well
frame
engine
now all we need is some money
small update
We got some 34x10.5x15" used tires for it mounted on original but painted black steel wheels. They are set in front for mockup presentation. Also got a replacement floor pan from classic ent to get welded in and the body work will start in a couple weeks.
And the first spring shot of the rookie driver...
finished scraping foam....
As bigwalton told me..this wasn't going to be fun, and it wasn't.
start
half done
done
Ah, the memories...
When I did it I cleaned out the stuff every so often... it looks amazing with all of it sitting in there like that.
Did they spray paint it or undercoat it? What's the black?
The black shows best in the first pic. Someone thought it would be a good idea to paint the foam black.
The most interesting pic for me is the one looking from the rear through to the dashboard seeing everything reversed. The mirror image dashboard pad, the dash, steering wheel, etc. It is pretty interesting that AMC would make all these custom parts for such a short run of vehicles. How much time was spent removing that foam? Nice work... looks like it cleans up pretty well.
Jeff
There are likely more RHD Scrambler-like jeeps than there are LHD if you look globally. The Overlander and Llanero (IIRC) was being sold in Australia, Venezuela and elsewhere with this hard top in RHD form while the Scramblers were sold here and I believe production of jeeps based on the Scrambler were being produced outside the US for some time after they were killed off here.
There's a thread right now about a guy in Venezuela who's building one of these that has a YJ grill and that was the stock setup.
So all Jeep did was borrow parts already in production for overseas to make this. There's nothing that's particular to the AK postals other than the postal tray, mounts and possibly the rollbar netting that they had when used by the USPS. But the only place I've seen the netting is in the restored one at the Alaskan Museum of Transportation and Industry in Wasila.
link
