You buying the top off of ebay in Chicago then?
I sent the question to the alaskan postal group, we'll see what comes of it.
BTW, if you are buying the top to put on a normal Scrambler, you won't have the bottom hinge bolt holes for the back door and the captured nuts to bolt it to. Last time they had that top posted they failed to make any mention of that issue.
It's not a big deal if you don't mind cutting a hole in the inside of the tub big enough to get to the back of the bolts.
You'll also have to cut access holes in the underside of the top part of your windshield frame and corresponding holes for screwing the front edge down. I went through a few dremel discs working on those when I replaced my windhield
I have good pics of this operation, but I haven't gotten them posted to my website yet. I would be sure to take the windshield off the Jeep to make the holes, they are a PITA with the windhield mounted.
Just making sure that you know it's not a straight bolt on arrangement. Going from the World Cab to the half hard top (as I think the Northern guys were talking about) is considerably simpler as all the holes are there.
Good luck and I hope it works for you. Let me know if you have other questions.
