Alaskan Postal door swap??
Ovrlndr Wannabe
Ok you Alaskan Postal owners PLEASE help. I would like to know if the stock rounded corner doors will fit with the postal full hardtop. I know that there will be a big gap at the corner but I think a body shop could fabricate a metal plug for that. I just need to know if the rest of the door is the same, the height, rake, etc.
Has anyone actually set a rounded door on the hinges to see if it would fit?
I have never actually tried it, but I'd put really good money on it working fine, just with the gap you know about.
I don't have another set of doors to try it with. I've thought about it being easy to fab up a corner piece as well.
Good luck, I'll be interested to see the answer. I have a Yahoo group for postal owners that might be the best place to post this, try here . Someone on there may have tried it already.
Has anyone tried to fit them.
I really don't want to find out in the middle of a 3200 mile round trip to pick up the top that they don't fit!!
I haven't tried it but every one I talk to said that I could go from the Postal Top to the Scrambler Half cab. They said I will need the doors from the Scrambler of CJ7 to match up with the top. The guys at Northern 4X4 in Anchorage are the ones I got the information from. They said they had converted a few of them.
It's getting kind of late in the year to do a 3400 mile trip to pick up a top. Have you checked ebay for a full length glass top? That would be any easier route.
Lenny
PS: Where are you at in Utah? I'm originally from Vernal.
I'm sure you could go to the half cab and CJ style doors with no problem. The problem I have is trying to use CJ style doors with an AK Postal hardtop. The top corner is curved on the CJ and square on the AK Postal.
From your response I suspect you must own a postal.
I'm currently in St George, UT.
I will send you a pm.
You buying the top off of ebay in Chicago then?
I sent the question to the alaskan postal group, we'll see what comes of it.
BTW, if you are buying the top to put on a normal Scrambler, you won't have the bottom hinge bolt holes for the back door and the captured nuts to bolt it to. Last time they had that top posted they failed to make any mention of that issue.
It's not a big deal if you don't mind cutting a hole in the inside of the tub big enough to get to the back of the bolts.
You'll also have to cut access holes in the underside of the top part of your windshield frame and corresponding holes for screwing the front edge down. I went through a few dremel discs working on those when I replaced my windhield :D I have good pics of this operation, but I haven't gotten them posted to my website yet. I would be sure to take the windshield off the Jeep to make the holes, they are a PITA with the windhield mounted.
Just making sure that you know it's not a straight bolt on arrangement. Going from the World Cab to the half hard top (as I think the Northern guys were talking about) is considerably simpler as all the holes are there.
Good luck and I hope it works for you. Let me know if you have other questions.
That was the one I was looking at (on Ebay). Do you know of any that are closer to UT, and with side doors?!
I figured the lower hinge would be an issue.
I didn't figure on the windshield. So it doesn't bolt on like the half hard cab I have.... I would appreciate the pics of the surgical operation needed to make this bolt on. Is it something I can do when I get to Chicago?
This is sounding more trecherous every minute....
I still cannot get Yahoo to send me an email to authourize me.
Thanks,
Mark
Doors, Doors, Doors
OW
If I get a chance this weekend I will see if my scramber doors will fit on my Postal. I park the jeeps apart. Together they just atracked too, too much attention. I am sure they will fit, like everyone thinks.
post some pictures of yours if you can.
see ya
I would really appreciate your checking. Take a pic if you get a chance.
I tried this once but the pic was too big so here we go again.
This is in Southern Utah on Sand Mtn. Not the best shot but not so bad.......
There are I think two AK postals on Elmendorf For Sale. They don't have for sale signs, but when I was looking at mine someone told me the guys at the fire station who have them would sell them. I just bought mine last weekend. I wouldn't want to attempt the round to square door swap. I would hold off until I found the complete set up. You will be much happier in the long run. Once you modified the top it would be hard to go back the other direction. If you found the correct doors. The one I bought has had the windows put in the sides of the top so it looks like an overlander. I'll try and get a pitcure up tomorrow. They show up for sale quite often.
You might try putting a want ad up on Northern 4x4s forum. Most of the guys on it are here in Alaska and been around the Postals since they were auctioned off originally you may get lucky and get the setup.
Lenny
I assure you I don't want to use the rounded doors. But the correct ones seem in short supply down here. In fact the tops seem in short supply. Oh well, if done correctly I think it will be OK as long as the rest of the door fits properly.
I don't know what the postals go for up there but it would be a fer piece to go for one! I think going to Chicago for this top is slightly insane!
Put up a pic of your postal it should be a great Jeep. I've had mine for 15 years and still love it.
Here's a little more studly pic of the Jeep from Canyonlands National Park, UT.
it is a "fer piece" that's for sure, 5543 miles (off the top of my head) but WELL worth it! Ovrlndr... have you looked at the rockcrawler.com link in my signature yet :D
The only Jeep made in the US with this top was the Postal Scrambler and with only 230 of them made (many of which were junked right after they were auctioned off) there's dang good reason for them to be hard to find.
The doors are a little more plentiful because the CJ-10 airplane tenders that the air force used had them, but no publicly available Jeep did (in the US).
In the lower 48, you'd be pretty hard-pressed to find a top up for sale. If you really want one, Chicago is a lot closer than AK.
Well, that's what I'm thinkin' Chicago is closer than AK. However, I've always want to cruise AK.
Yeah, I hope that the CJ doors will fit. With a little extra metal to fill the hole. If I eventually found the correct doors I could remove the filler and use them. I think the top would look better with them.
So who knows. Hopefully sgt. will provide some info on the fit. I'm sure that they should fit but don't want to bet a trip to Chicago on it. Since you are so familiar with this top check this link and review the pics. Let me know if you see any obvious problems, or not so obvious...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2434801048
You'll have to copy it into your address bar.
front rake matches!
The front rake angle matches!!! I got a new wing window from Rubberhook here on the boards when I was at Oak Ridge and I'm sure it wasn't from a World Cab door, the rake and height are spot on. I didn't even think about the fact that they might be different when he offered it! Guess I was lucky.
I would say that pretty much assures that regular CJ doors will fit fine.
BTW, there's a sheet metal "channel" around the door opening that I would think would make an easy place to screw a metal chunk to fill the hole. I bet, with a little ingenuity, you could come up with something pretty easily that you could even make fit well enough to seal up with the factory seals.
I was looking at this channel and corner for this exact purpose with the thought of putting on some soft doors. I just never thought about the fact that regular CJ doors wouldn't slide right on. Guess I didn't need to worry either :D
Thanks, I'm most concerned about the top and rear. I feel this is where if they were going to make a change it would have been easiest. Man I hope they didn't change it!
I sent you a pm.
Well, here's a test fit of a CJ door on a CJ10 aircraft tug with the World Cab. The guy doesn't want to sell it it's being "stored" in a wrecking yard.
Same old story the guys going to fix it up. I don't know why its missing tons of parts and has a Nissan diesel engine??? Hey thats what the oil cap said amongst other jap writing.....
Sold??? Doesn't look to sold to me! There's one of your future doors right there! I'll take that half top if you don't want it. Screw this Sold junk...
Seriously, what's the deal with that -10? I'm dying to know. A half hard top with the World Cab corners would be SWEET!
Man, that thing looks like it's in great shape... you gotta tell me what the deal with it is!!
