Alaskan postal top fix
chuckpostal
New member
spokane
wa
I am cleaning up rust from my hard top before winter and was wondering what seem sealer someone would suggest to use. Grinding, sanding and then a rust converter, seam sealer, then 2k epoxy primer. Is this a good plan?
Also is there sealer or just paint in the seam in the picture? Looks like paint to me in this one, but all around outer edge does.
Here is the outer edge picture.
3M Urethane Seam Sealer, 08368, White, 310mL Cartridge​
This is what I am using for the seams of my postal top.
Do you think there would be any problems over rust converter? Should I seal then prime? or prime, seal than prime again? Swapped in 4.0 and Aw4/300 and wanted to stop rust from killing what seems to be a nice top before I start wiring and everything else.
Personally I'd epoxy prime then seal then touchup with primer, but check the directions on what you're going to use for suitable substrates regardless.
I have no expertise to lend here but very jealous of getting the top situated properly. Mine has lots of small issues like this that add up to a massive amount of work to do right. Sadly, I don’t really ever see me getting into it. :shrug:
