sdsupilot
- OKC
- OK
I am inching closer to installing my narrowed J10 dana 44. Steering is apparently quite an issue with this setup. I have read all kinds of threads about different options.
I am planning on running a Y link steering setup similar to a stock waggy. I will either run a factory waggy pitman or an Astro reamed to stock waggy/gm taper.
I want to avoid the issue of tie rod/pitman arm contact. I think with the MORE mount moving my steering box 1 1/4” forward, plus some tie rod bending should alleviate the issue.
I think something like this might work. I don’t think I would need
Obviously it might take some strength out of the tie rod, but this is 1” thick solid steel.
Am I crazy, or is this plausible?
