trust
PITA
- White Rock
- NM
Ok all, I'm at a critical point in the resurrection of my 83 scrambler, drive train selection. My options are essentially one of the following three with my pros and cons. I would really appreciate some input from this august body of experts. PLEASE point out flaws in my thinking or pros and cons I've not listed, this is an abbreviated list but I haven't thought of everything.
Goal: daily driver and 4x4 touring with some moderate to difficult trails (Blanca peak Co for example)Most of my wheeling is in Colorado and Utah and is more extended camping vice obstacle course stuff (See the Piute Pass article in 4wd and suv, I was on both attempts)
Options:
1 304 v8 with a TF999 auto, d 300 and 3.73 or 4.1 gears, 35" tires, rear d44 stock front WT d30 with internal hubs Pro I have the 304 and 999, the d44 and d30, the d44 has 3.73 gears, easy, simple, cheap, a V8 - Cons EFI would be non factory, lower mileage than other options
2 4.0 aw4 d300 and 4.1 or 4.27 gears the rest the same Pro factory EFI , overdrive, better economy CONs more expensive (I don't have either engine or trans), somewhat more complex, may be unhappy with power, not a v8
3) 258, 999, rest the same as 4.0 Pro cheap, easy, factory reliability, Con lowest power, may not deliver any better economy than V8, needs aftermarket EFI
Others? I may look at a 360 vice the 304 but that would cry out for the Edelbrock EFI which affects the cheap part. Diesel would be great but that really undermines the cheap and simple approach
I await your advice
Options:
I await your advice
