any opinions?
trust
PITA
White Rock
NM
Ok all, I'm at a critical point in the resurrection of my 83 scrambler, drive train selection. My options are essentially one of the following three with my pros and cons. I would really appreciate some input from this august body of experts. PLEASE point out flaws in my thinking or pros and cons I've not listed, this is an abbreviated list but I haven't thought of everything.
Goal: daily driver and 4x4 touring with some moderate to difficult trails (Blanca peak Co for example)Most of my wheeling is in Colorado and Utah and is more extended camping vice obstacle course stuff (See the Piute Pass article in 4wd and suv, I was on both attempts)
Options:
1 304 v8 with a TF999 auto, d 300 and 3.73 or 4.1 gears, 35" tires, rear d44 stock front WT d30 with internal hubs Pro I have the 304 and 999, the d44 and d30, the d44 has 3.73 gears, easy, simple, cheap, a V8 - Cons EFI would be non factory, lower mileage than other options
2 4.0 aw4 d300 and 4.1 or 4.27 gears the rest the same Pro factory EFI , overdrive, better economy CONs more expensive (I don't have either engine or trans), somewhat more complex, may be unhappy with power, not a v8
3) 258, 999, rest the same as 4.0 Pro cheap, easy, factory reliability, Con lowest power, may not deliver any better economy than V8, needs aftermarket EFI
Others? I may look at a 360 vice the 304 but that would cry out for the Edelbrock EFI which affects the cheap part. Diesel would be great but that really undermines the cheap and simple approach
I await your advice
Door # 1.................
Option #1 gets my vote. The reason is because you have this on hand. With the TF999 you'll get away with the 3.73's and 35's, but 4.27 would be better (I'm 33's and 4.10's). Howell FI is good on this combo (I've got it on my 360) and uses off the shelf GM parts. For your terrain you may want to go with a 4:1 kit in the transfer case for crawling. The only drawback I can see is a lack of an overdrive on it as a DD.
I would vote for option 2 as well. With the proper gearing, the 4.0 liter will give you more than enough power and should be extremely reliable.
Terry,
I dont have an option choice, but what I can tell you is this....
I run the 4.0L (out of a '93 GC W/fac EFI) in mine with a T-5. I ran 4:10's with 35 in tires.
On the Street: While it was 3rd gear going up the [steeper] passes, most hills were 4th gear and it did well on the straits, even used 5th gear all the time.
Off Road: Surprisingly enough I rarley used 1st gear on the trails around here. Except some climbs and steep decents I never used first.
I have found that the 4.0L has plenty of torque and power for all around driving. I like it. Does it sound as cool? No. Can I go any where the guys with cool sounding V-8's go? Yes.
John has a very good point, you have what you have. Would I have done a V-8 at the time if it were as availible for the same money? In a heart beat.
The next time mine rolls (after 5 months on stands) it will be the same set up with 37in tires. I bet it will be quite weak on the Street and I'll be using 1st gear a bunch more than I did before on the trails. When I do my axels I'll be doing 5:13's, what ever I go with.
Just a side note: Before spring over running 70-75 smoothly was nothing, after SOA, not a chance. Maybe 60-65 maxing, after that is just scary.
Terry, as you know I basically had option #2 with the 4:10 gears except 33 tires and was overall pleased with it except I wanted a more aggressive suspension. There was no issue at all with the power and performance of the 4.0.
However, I am not sure about the economy. I have never really used the 4.0 as a dailly driver so I do not know what it would do in that environment. I do not believe it would get better than 12 - 14 mpg though.
Did you solve you over heating problems with the 304? If so, what was it?
I would go with option #1 if that was what I owned and where my knowledge was.
When will you be arriving at Moab?
Ken
PS. I bought some 15" MTR's but thanks for letting me know about the 17's.
Door er Option #1 gets my vote because you own it and down the road a 360 would make the package correct and easy to do!
Thanks Guys, I appreciate the input, I'll let you know how it goes.
Ken, I sold the CJ5 with the overheating problem not fully resolved but not seeming to be a problem in that it sort of quit doing it but not as a result of anything I knowingly did.
I will probably be in Moab thursday the 8th unless I can get out of here Wednesday. leaving on Tuesday the 13th or so. I'll be sure to hunt you and John down, you're at slick rock CG right?
This is just my opnion and doesn't reflect the majority.
Go with a v8 you can waste all that money on a 6 and still have a 6. You will appreciate the v8 more.
Use the automatic much more smother delivery of power.
put the 4 to 1 kit in the transfer case this will take care of your gear problems and allow the 373's for better highway.
BLANKA PEAK IS NOt AVERAGE 4 WHEELING you better hope you have lockers for that.
I am very happy with my 401, 4.56, 35", 4 to 1, auto, combo.
I put in a smaller torque converter that kicks in at 800 it pulls right of idle. Won't allow a big cam though. I had them build hold back in it. It holds back as good as my 4 speed did. All has to do with gears.
Look for the Brightest green CL7 in Moab at the best western and well talk.
thanks Wyoming, Which auto are you running?
I'll keep my eyes open for your CJ7, I'll be in my ersatz scrambler, a Comanche - white with a red hood and a blue LF fender with stars - collar me if you spot it. That goes for anyone else who's in heaven for EJS.
The auto is a 904 out of a 84 CJ7 I had the shop beef it up for the 401.
I have another 904 and 401 for my Scrambler I will be starting on after EJS. If I could find the money I would like to get a Klune v and use it as a overdrive. It will work in all gears and low range.
I have the 999, it was rebuilt/beefed for the cj 5 but I never installed it and it's just sat in the garage. I had thought about using the Klune instead of a 4:1 in the t case and using higher dif gears for the highway and I thought it would be nice as an adapter if I used an early aw4, but as an OD hadn't occurred to me, to bad the cost is so bloody high.
When you installed the v8, did you need to use the pass side motor mount tower from a cj or will an SJ one work? Anything else that needs to be done before installing the motor?
thanks
BTW, I 've done Blanca peak a few times and know what you mean about being not average, I am sort of using tht as an upper limit on the difficulty scale for the scrambler. In otherwords, I have no intiention of trying to horse this thing through Tabasco Twister or upper Helldorado.
I have been up both Tobasico twister and Rotello rapids, that area will put a hurt on your unit and the jeep too. I quit going there I prefer more recreational 4 wheeling. When you put in the v8 you have to replace the passenger side frame mount. It's not real expensive from Jeep. You could buy more motor mounts, tuff but costly. The fuel line is probally on the wrong side no big deal. A word of advice spen the money and by the expensive fan shroud for a v8 it will help with overheating. The trans should bolt right up. you will probally have to fab the skid plate and get new drive shafts. Think about clocking the t-case not really that hard smooth up the bottom. I did it myself with careful redriling. When you get to Moab call me 307-631-1282 if you want.
thanks for the info, I picked up a 360 over the weekend (already have a usable 304), unsure of the condition, and I believe it has the right motor mount tower (doesn't matter if it's from a CJ or a wagon does it? and how do I know if it's right or left?) so I'm cleaning parts and getting ready to pull the remains of the stock power train.
I'm with you, I like the touring and recreational stuff, the conquest stuff is just to hard on me and my stuff. Besides, chicks really don't dig body damage, they like nice clean well kept bodies.
Moab suddenly took a hit, $@#!@$% job, IF I make it up at all I'll hunt you down, thanks.
tr
