Hi Eric, I just went out and measured the clearance for you. I have 16 inches from the ceiling to the top of the hard top. That is about as high as I can raise it due to the room needed for the hoist frame (that holds the top) the eyebolts (that hand down from the ceiling) and the pulley assembly that is in between the two. With the 31 inches of the hard top, I can JUST pull the Scrambler under it with an inch or two of clearance.
Again, If you order one of these from Lange, you MUST tell them you need to place a special order for one long enough for a Scrambler! And make sure the electric motor is compatable for the extra weight of a Scrambler Hard top. I REALLY like mine!
