Anyone Here Knowledgable in Early Broncos?
Dave K.
Milwaukee
WI
Looking at buying one locally and had some questions about them including the auto/C4 transmission. I know the rust prone spots (everywhere) and other things to look for but want to understand the performance of these with the 302/C4 combo. When I drove the truck it seemed to be screaming in top gear (on the hwy at 55-60 it seemed like it was pushing 3000 rpm or more.....and with no tach it's hard to judge if it's slipping or not. The transmission did shift strange with an almost instant jump to 2nd whil accelerating. Fluid was topped off and didn't smell burnt or anything. Also looked clean.
**Don't know the gear ratios in the diffs but the truck is all stock, unmodified near as I can tell.
Thanks, Dave
3,000 rpm is high for a stock v8 bronco; v-8 bronco should be in the 3.50 range and the I6 is around 4.10. I've got 4.10 in my cj5 and the SBC is spinning 2800 rpm at 55-60mph with 31" tires. I'm guessing that your transmission has been worked like a rented mule.
My experience with EB's is with manual transmissions, but 40below is correct- V8's normally came with 3.55 gears. With stock tires in drive this would be 2800rpm at 65 mph. With 4.10 gears, which were optional, you'd be spinning about 3200 rpm. This is figuring a 28" tall tire, like a 235/15. A C4 will normally shift to 2nd pretty quickly, especially if you're used to GM or AMC transmissions.
There's not many that haven't been modified, and swapping to 4.10 gears is pretty common. What year? Any pics? those things are uber-cool, and the prices are crazy- so if you find a good deal, jump on it, you won't be sorry. Most body panels are available, so rust repair is not too bad.
We're currently building a 70- D44 front with discs, True-trac and alloys, 9" rear with Detroit locker and alloys. 1986 HO 302 EFI, C6, 205 case. 4.10 gears and 36" Irocs. Should be cool!
Need pics of what you're looking at!
Always wanted one. Used to be early Bronco's all over the place in great shape for $2500-3K (when a comparable CJ was $6-7K). Wish I'd picked one up along the way.
Guy in High School had a 74, hunter green with a tan top. V8 (not sure which) automatic. That thing was sweet. He hit a guard rail with it during an ice storm messing up the right front fender and relegated it to a hunting lease vehicle. Wonder whatever happened to it.
Not perfect but pretty much rust-free aside from the tailgate (a spare is included) and original paint. Interior is the brown naugaleather with houndstooth. I believe it's been smacked at one point in the left front fender but it runs down the road straight. I've gotten to know these some from looking over a number of them. I pulled up the carpet, pulled the tail lights, crawled around all over and so on trying to find rust. Rockers are solid, doors as well, some small kick panel rust but the front wheel wells are rust free as is the battery area.
Thanks for the input, I was able to confirm that the gearing is 4.11 rear which would account for the screaming. I guess I'm going to have to change the gearing out at some point..... now to find someone in the Milwaukee area I can trust to do it. Our old trustworthy place is gone now unfortunately. They could set up gearing in a heartbeat.....
Pretty. I like them with fender flares, but no way I could cut one that was uncut. I always said if I bought one I'd have to find one that already had flares so I wouldn't be tempted to cut an original one.
Wow. That's a beauty! Did you buy it already?
How about running 33X9.50R15 BFG AT's? That would make up for the high gearing and those should fit on the stock wheels in the wheelwells.
You know, 4.11 works real nice with 33's, and 33x10.5 can clear the fender skirts with the factory wheels. That is my favorite look. (and now I read Randyzzzz post and see he has the same idea). The ones that have survived uncut really look sharp.
Your truck looks good, also check the fuel tanks (the outside) for rust, I was tapping on a 73 EB fuel tank and went through, which ended with 8 gallons of gas in random buckets. Oh well better in the driveway than on the road/trail.
Yj-8
Congratulations! Nice Bronco.:thumbsup: :wave:
Thanks all for the input above. I'm picking the truck up on Saturday and will post more pics. Likely I will go with the gearing swap down the road as I like the stock stance. Also, Ford did that funky thing with different gear ratios front and rear because they ran slightly different tires on the front? WTH? Anyway, I would standardize on the gear set and then get the same size tires if they aren't already. I'll have to check. Some work to be done but all in all I think it's one of the nicer Broncos I've seen out there for less than $12K!
Wow, nice find!
Was it local in the Milwaukee area?
Did you end up selling one of your Scramblers? IIRC, you had mentioned selling one a while back.
ImageUploadedByTapatalk1413704721.574941.jpgImageUploadedByTapatalk1413704755.624485.jpg
Saw this sweet Bronco at the Big Bass Bash awards ceremony at lake of the ozarks in MO a few weekends ago! Winner took home $70k for a 7.89 lb bass!!!!!! Think of the Scrambler(s) you could build with that cheddar!!
