Not sure about the commercial stuff. But, I have used the at home thing that Northern sells.
It uses a siphon tube to bring the sand up into the Pressure Washer stream. The problem is that the sand has to be completely dry or the siphon will clog, and it goes through sand quick.
It does a good job removing stuff from heavy steel like the frame, but I would not use it on body sheet metal. I have seen a system where they use Soda on Sheet metal in a water stream, but it seems like the paint guys are having a lot of issues with soda on metal. It is reacting with the paint and then lifting once the job is finished and out in the real world. Seems like some of the paint manufactures are not standing behind warranties if soda blasting was used to prepare the base.
Check into this before really jumping in on it. Seems that Soda companies are pushing the material hard, but real world experience may not be as good as promised.
I like the idea of using water to keep dust down, but in practice not sure how it works.
Are you looking at full up commercial stuff like heavy steel, or more things like sheet-metal in cars???
Carl
