Attention Bigwalton
Dodster
Mechanicsville
Va
Eric, Sorry to disappoint you but Labor Day weekend at Crabtree Falls/Shoe Creek was very hard on my 8. Front wheel bearings badly need replacing and front pinion seal is leaking very badly. These were items in need of replacing anyway but this past weekend's very hard wheeling revealed the severity of their need for attention. This means my 8 won't be at Oak Ridge.
But I had one hell of a weekend wheeling. Up until now I had always been a little nervous about my narrow track axles. But now I am very confident in my 8s capability and my skills in piloting it. I had that thing flexed up on 4 foot rocks. There is one rock up there that has a flat face and wide enough to get both front tires on it. It is pitched at better than a 45 degree angle. We had 2 CJs 2 XJs and a TJ in our group. When crawling up the face of the rock to get all 4 wheels on it, everybody but my 8 scraped the ground with their rear bumpers. Obviously the spring over gave me plenty enough lift to clear the ground. I didn't have a camera but my friends did. I will post pics when I get them. You should've seen my front axle flexed on those big rocks. My left front tire totally stuffed and the gap between my right front fender and the top of my right tire was impressive for a leaf spring suspension. Or at least impressive to me. To give you an idea of how flexed my Jeep was, and you have to picture how tall my 8 sits, I had to reach DOWN into the bed of my 8 on the right side to get a beer out of my cooler when my 8 was flexed at it's max. My springs on the front left and right rear were bowed upward.
As you can probably tell I'm pretty stoked about my 8s performance. I made good use of the 3 day weekend to learn how to really drive that thing. I am very disappointed I won't make it to Oak Ridge. But if you or anybody else ever make it to Crabtree Falls/Shoe Creek with me it will be worth the trip. Since I was shown new challenges to tackle by someone who owns property up there.
Dodd
Stoked
That is AWESOME MAN !!!!!
I do that quite alot. Feels like a great accomplishment when something like that happens.
Where is Crabtree falls anyway. Now that i am getting to kinda know you guys i will try and hit alot more places to wheel. I am just more used to staying around the Hot Springs and Gilmer area seeing how that is only 6 hours from the house. We are trying to get out more and probably to your area one day.
Keep on Keeping on Man.
Wheel bearings are easy to replace... and we'll just stop every so often to fill up your axle if it's leaking. (May have to do that for mine if'n the new seals don't stop the leaking I have).
C'mon, none of that stuff is a show stopper...
Hell, my rear axle is sitting out from under my junk right now completely disassembled! The only thing left in it is a pinion! I'm hoping to have that all back together in time to wheel THIS weekend... much less in time for Oak Ridge!
*Eric puts on the cajun's voice from The Waterboy*
Yew can dooo eeeet!
:D
Normally these things wouldn't be show stoppers but I'm still recovering financially from all the bullsh!t my ex has put me through the past year and a half. So funds for bearings and seals are not readily available. I'll be back in the chips in a month or two. Plus I don't have the facilities to do the work. I have to use a friend's garage when he's got time to let me in.
Scott, CB Falls/Shoe Creek is in Va between Charlottesville and Lynchburg. Come on up sometime. I'll show you around.
Dodd
Well damn, I'm sorry to hear all that... like me at the national, at least you had fun busting your junk!
We have a plan for a trip to Uwharrie down here in NC on Halloween weekend, it's looking like there will be quite a few of us. If you're able to get it back together by then, see if you can make it.
Looking forward to seeing you back on the trails! :D
Excuses, excuses... let me help ya out...
Dodd
Dodd,
Don't know ya, but any friend of BW's is a friend of mine...:) As well, I can appreciate "ex's" and how they can tangle you up.:mad:
I'm not for sure - will have to wait 'til I get home and look in the box - but I think I have the bearings and seals you need for your front axle if it is a stock Dana 30.
Anyhow, if I've got the stuff, I can/will 'spot you' for "a month or two" 'til you're "back in the chips". :)
The material was bought from Krage/JeepDoc.com and Randy's Ring & Pinion for the gear swap I intended to do before I bought Ken Waters axles. In fact, you'd be doing a favor if you used them and instead of replacing them, just give me the cash.
I'd be pleased to do it (I'd consider it a blessing if you let me help you out) - if you're interested, give me a holler. Since we are relatively close (50mi), getting it to you should not be much of a challenge. So far as a place to do the work, my driveway is already full:p , maybe someone else in the area can help out - there's lots of us in VA. Guys? Anyone?
I'll check my parts 'cache' when I get home and repost then. 'Til then, think about my offer and maybe someone will pony up a a place to do the work.:)
Dodd, you and Jerry will get along GREAT, you're real similar in a lot of ways and would have some great stories to swap.
It'd be great if you could work this out. I would offer up my garage but I'm afraid it is of little help in the current situation.
Trust me, Jerry NEEDS to get some junk out of his garage! His wife will thank you! :D :D If you do manage to work something out, you ought to think if there's anything else you MIGHT need. You ought to ask if Jerry has it, he's got one of the best stocked Jeep junkyards....er, garages of anyone on the board :D
One evening.............
Dodd, that's all it'll take to fix that stuff. So....back away from the TV and you'll make it happen. Let me know if you need something. I've got the spindle nut socket, too.
Aw shucks Eric, you're embarassing me...
Actually, the stuff Dodd is in need of is in the laundry room... Wife moved it there from the "John Wayne Room" (aka family rm), and b/c it's all in nice, clean, new boxes, it has not made it out to the 'less-clean':rolleyes: garage yet.:eek:
Now THERE'S an understatement! But to be honest, I think she's pretty much given up... (There's hope for you yet Eric! Just wear Kate down... she's bound to throw in the [shop] towel eventually!:eek: :D LOL)
Re: Aw shucks Eric, you're embarassing me...
...you guys are killing me.......:D
It's a Jeep you should be able to do the wheel bearings witout a garage. I did mine last January in the middle of a hunting season while it was 15 degrees out. Then did the rear axle swap in the same conditions. Garage?? We don't need no stinking garages... We are jeepers!
It is a half day project if you take your time.
In the water boy voice
"You can do it!"
TK
Jeepers are awesome
Thanks much for all the support guys. I really appreciate all the offers. But I haven't sent in my app for Oak Ridge and it's already Wednesday. I was really bummed Monday when I realized I couldn't put off necessary repairs any longer. So I figured the $50 for Oak Ridge would be better spent on badly needed parts.
The pinion seal I can do in my driveway. But I don't have a floor jack and don't want to put my life in the hands of my hi-lift jack. Changing a tire is one thing. Pulling the hub off is another. I'll slowly gather the needed funds in about two weeks.
Jerry, If it means that much to you I'll gladly buy your parts. But I want to put cash in your hand when I get them. Perhaps we can meet at Massaponax and grab a bite and swap Jeep stories.
Thanks again guys.
Dodd
OK, Dodd....Jerry gonna spot you the parts....John will help you get em in...now let's put some real arm-twistin on ya...I'll buy all your beer for the weekend! (Wait a minute! What am I saying?:D :D ).
OK, seriously, the offer stands, just to give you added incentive to make it, if possible. Sure hope you can!
P.S. this offer does NOT extend to the rest of you guys!!!:p (except John N (if he decides to start drinking again...won't happen!...for ALL the help he's given me with my rig) or Fernando for hauling me and my 8 all the way to Arkansas and back (but I know all you guys who are getting the Hot Springs DVDs from him are gonna be setting him up anyway!)).
BTW, all the repairs/maintenance stuff on my jeep are taking a back seat to digging trenches and laying drainage pipe/tiles around my house to prevent any more flooding from future Hurricanes (can you say Ivan) like we had during Gaston and Frances. But I'll be at Oak Ridge ready or not!
L8r
-Mike W
OK, Dodd....Jerry gonna spot you the parts....John will help you get em in...now let's put some real arm-twistin on ya...I'll buy all your beer for the weekend! (Wait a minute! What am I saying? ).
Shoot, this is only a couple of hours of stuff. We've got 2 weeks, but the form still has to get sent in on time or call them and say you're sending it (I hope that'd work). Dodd, you've still got an application into Capital City and fulfilled the required stuff, so you can do it for $35.
You guys are the best!!
I really do appreciate all the offers but I have resigned myself to missing out on Oak Ridge this year. But next year at this time I'll be sitting pretty and shouldn't have any issues to stop me from going to Oak Ridge.
Dodd
Slippery Rock
Eric, I forgot to mention that last weekend I got up that rock that I had to winch off of 2 years ago when you rode to Shoe Creek with us. You have a pic or two of it on your website. I got up that sucker on the first try. The success of last weekend is mainly due to airing down my tires to 15 psi. Just thot I'd share.
Dodd
