Best Gas?
Regular or Premium Gas? Or Does It Vary?
  • Total voters
    13
IanCharles
Baltimore
MD
From what I gather, octane is a fuel's resistance to knocking or combusting before it should. The '82-'83 Jeep Factory Service Manual - Maintenance Section - says to use a fuel with a minimum Anti-Knock Index (AKI) of 87; and that a lower octane is acceptable at elevations above 1,500 feet.
I could see upgrading to premium to eliminate engine disruption from premature combustion, but our CJ8s have knock sensors which exist for that very purpose.
I've been using premium gas, but I switched to regular a few weeks ago. I noticed a slight loss of power, but I saved enough to buy a candy bar. What do you think? Premium or Regular? Why?
IC
I use regular because the manual said that was enough, and it is cheaper. That's about it. In my wife's Mini and my old Audi, I use(d) premium because those require it and really knock when I used 89.
Your scrambler does not have any knock sensor. Only one in a CJ is your ear.
That's what octane is and if you don't have knock on regular the only benefit of higher grade gas is if it's got a higher additive or detergent content.
If youre running premium, youre wasting your money. Not needed in a CJ.
A Ferrari, yeah that needs premium, but mine is in the shop. ;)
The later year CJ's do have a knock sensor, it talks to the under dash computer and will adjust the timing to prevent knocking:thumbsup:
:confused: well that's the first I've ever heard of it and I've never seen one. Interested to look it up now. Still learning after 10 years of this forums existence!
Here is a link that shows the location/description:thumbsup:
http://dale02.home.sprynet.com/knock.htm
The later year CJ's, with the computer controlled carbs, are actually fairly advanced pieces of engineering. These engines have most of the same sensors as an injected motor, due to trying to squeeze out every last bit of efficiency/clean running ability. The problem, most of these sensors are more along the lines of mechanical/vacuum operated controls, which are more prone to break downs, then say a MPI equipped 4.0, where everything is electronic. Basically, it is much easier for all this crap to break on a CJ, vs a newer 4.0. They both try to do the same thing, but obviously one is much more reliable then the other. Hence, the reason why most of this stuff is disconnected, either fully or partially, making the jeep run even crappier then before, then taking the easy way out, blame the BBD carb, when in fact it was an "input from a sensor" problem leading to a bad output from the carb:crazy:
My green Scrambler still has most of the original sensors/wiring/vacuum stuff hooked up. The biggest thing I am missing is the "Pulse Air" components. I am going to take most of the computer controlled carb stuff off of the yard Scrambler (I am converting it to a 1982 fuel/spark system) to keep as spares/install for missing parts for my green Scrambler. I am going to attempt to actually get all this factory stuff operational, boy do i like a challenge:crazy::thumbsup:
PS - That site above has the best information on how all the computer controlled carb gizmo's are supposed to function, a very useful site for reference for troubleshooting, or just to increase knowledge. I have found it very informative:thumbsup: After reading about all of the sensors/functions/operations of all the components of a late model CJ, it makes MPI seem like child's play:crazy::crazy:
Just remember that most markets now have E10(up to 10% Ethanol added) and E15 is on it's way shortly. What that means is that the tune in the factory carb if it has never had the metering rods adjusted or changed will be running lean. The E10-E15 fuels will have a leaner mixture than the fuels the original carb was calibrated with in the 80's so to get the same power, it now will require a larger volume of fuel than originally calibrated. So if the motor is now running leaner than originally calibrated, then it will be more prone to detonation. So generally speaking, a higher octane can help but it may not be the correct fix for the problem. How's that for stirring up the muddy water?
Very interesting thoughts on the "ethanol problem", that is why I use 100% "Pure"/"ethanol free" gasoline in my green Scrambler:thumbsup:
http://pure-gas.org/
Non-ethanol gas is all I put in the Scrambler, actually all of our vehicles and EVERY ONE OF MY SMALL ENGINES (mower, blower, weedeater, chainsaws, hedge trimmers, etc.)
Ethanol is bad juju.
ive got my 4 banger tuned to run off e85 at the moment. just so i can use my still and some free silo juice to run it. i just add some gas to it for the detergents
and other stuff in the gasoline.
ethanol really isnt that bad its just got a little less power than gasoline.
Naw....It's not bad...It just eats your non-compatible fuel lines from the inside out. Basically anything that is rubber that is non-compatable it will destroy.
I'm on my 5th fuel pump in 65000 miles. I've been told ethenol is probably responsible. Also have had to rebuild the carbs on all my mowers, chainsaws, etc. I don't even know of a gas station around here that doesn't sell ethanol. We don't have much choice. I have started running premium in the Scrambler (4.0) since installing the last fuel pump but don't know if it will help.
We have a few land based gas stations around here that sell "ethanol free" gas, 87 octane. It usually costs about the same as ethanol premium fuel, so not too expensive:thumbsup:
Also, all of the marina's down here sell ethanol free gas, in all grades, but it costs more to buy "at the dock";)
And yes, the ethanol gas will eat non-rated fuel lines:eek: On my green Scrambler, when I dropped the factory gas tank out to change, the original factory rubber lines coming out the top of the gas tank were beginning to get all "gummy" on the inside:eek: I ended up changing out all the rubber fuel lines on this Scrambler as a result of seeing the damage:confused:
At work, any piece of small equipment has had problems with carbs/fuel lines from the ethanol gasoline. That crap might be fine for newer vehicles, but on older vehicles, it will play havoc:twocents:
Most all E85 vehicles have stainless and teflon lines to stop the deterioration and corrosion that alcohol causes.
it doesnt really eat it away as fast as everyone thinks. people just complain when it wears out their "non compatable" fuel lines. they seem to think that 20 or 30 year old fuel lines should be invincible. and most fuel line you buy now is resistant to it anyways. ive been running my garden tractor for 3 years off straight ethanol without even replacing the lines or any seals in the carb. its not so much as eating away the rubber it just kinda dries it out but it takes forever for it to damage a fuel line. most people who have had problems blame it on ethanol fuel but they could trace their problems back to improper maintenance. more than likely you will end up fixing everything else on your jeep before the fuel lines give out. it cost me like 25 bucks to update the fuel lines in my 81 cj8. im not saying ethanol is the answer to everything but at least i know im not spending 3.80 a gallon to drive it. oh and ethanol doesnt go bad either just as long as it doesnt evaporate.
Ethanol sux...who in their right mind would convert food to fuel...especially when corn is only 30% sugar in the first place...this is all probogated by the ethanol industry...
A. 76,000 = BTU of energy in a gallon of ethanol
B. 116,090 = BTU of energy in a gallon of gasoline
C. .655 = 2/3 = GGE of energy in a gallon of ethanol. A / B. (GGE =energy in a gal. of gas)
D. 1.53 = Gallons of ethanol with the energy of 1 gallon of gasoline. D = B / A.
anyone that thinks ethanol is the answer is drinking the left wing cool aid... even the environmentalist are now coming out against it due to the amount of diesel required to produce corn based ethanol..
