Bikini top
Going Postal
Corvallis
Summers here and I need a Bikini top. Any idea who has the best price? Soft half doors would be nice too!
A few years ago I was looking for a bikini top and I seem to recall the research resulted in:
- The strapless models for CJ7s don't fit CJ8s unless you rake the windshield back. Why? The CJ8s roll bars are thicker and sit just a little further back from the windshield than CJ7s. Raking the windshield back is not an option since it will then interfer with the use of full hard doors or uppers.
- The old fashion strap bikinis work, but then again you might not want straps (especially if you are using a tonneau cover like me).
Here's what I did... I bought an old YJ soft top off Ebay. I then cut it down to sized and made a few stiches to hem it.
Actually, I got a little fancy and designed it so that I could choose from two options. First, I use the entire YJ roof material and only cut the "C Pillar" ends off the YJ soft top. This allows me in both (a) and (b) below to extend the top back to the rollbar (like any regular bikini) but then I either.....
a) wrap the top around the roll bar and then back forward towards the windshield. Then I sewn some webbing straps to the trailing corners of softtop. And finally installed two footman loops on each inside upper windshield corner for the straps to attach to.
b) wrap the top back down the back of the upper roll bar and down to the bulkhead to provide rear cabin coverage to provide some incremental rain coverage. Using the same straps in (a), I wrap the straps around the rollbar at the top edge of the bulkhead and clip them together inside the cab.
Viola! With full doors, I now have a semi-enclosed soft top with no need for softtop hardware. The only spot not protected from rain is the space between the door and rollbar.
Hope this helps,
Jim
Bestop bikini
Yesterday I picked up & installed a 'strapless' (meaning no straps to the back feet of the rollbar) Bestop bikini (part# 52518), described as a top for a CJ-7. Got mine in black. In order to install it, it required a Bestop Windsheild retainer kit (part# 51209).
Windsheild retainer kit required pre-drilling 8 or so holes, & then using supplied screws to attach the retainer to the top of the windsheild frame. This took about 15 mins total.
The bikini took about 2 mins to slide into the windshield retainer, & easily folded back over the rollbar. It has 2 straps at the rear corner edges that cinch it over the rollbar, & a third strap that comes back under the rollbar & ties back to the center of the windsheild thru the "footman loop". See the illustrations in the installation guide here:
http://www.bestop.com/installation_guides/52518.pdf
The back edge of the bikini top is preformed to match the curved outside edge of the rollbar, & fits just like the photo on the Bestop site...
With my hard doors on, there is a 1/2 - 1 inch space between the top of the doors & the side edge of the bikini. But I picked up the bikini top to provide some cover for my seats here on the springtime west (wet) coast. I will probably take my doors off completely for the summer months, so the space matters not. The jeep is in the shop for carb work, or I'd take & post some photos. Let me know if you need photos to make ur decision.
cost: $70 for the top, & $20 for the retainer kit (Canadian $$)
Black contrasts well with my copper paint...I'm happy with the ease of installation, fit, & look...
Ditto
Yeah, What he said. I got one for Christmas 2 years ago. Works well. Bestop.
The one thing I don't like is that the top is tight against the sharp top edge of the windshield, and will eventually where thru.
They guy who owned my roll cage before me had a really sweet one to provide shade. It just snapped onto the the cage so it could be used if you wheel without a windsheild frame, I can try to post pics of whats left of it (it took a nice beating in my rollover), I imagine that you could make a little one like it that would snap to the windshield frame and roll bar, and then remove the front snaps for the hard top if you needed the clearence. I had one of the strapless tops (I think it was best top but I can't remember anymore) and the one problem that I had with it was that it tended to fly off after driving on the freeway.
Yeah, that's what I seem to recall as the reason why I was told I'd have to rake the windshield back a little.
Slit a piece of vacuum line and put it over the top edge of the windshield frame- it will keep the top from being abraded by the sharp edge.
Quadratec carries one made by Pavement Ends, I think. Quadratec stock # 11027.xx for '76 CJ-'91 YJ. The "xx" on the part # is where you put in the color code.
These tops cover the rear seating area and have a little bow that attaches to the diagonal part of the roll bar that supports the rear of the top, very similar to the Rockgear one.
They are listed for 69.95.
specialty top
Specialty top also lists they have one but I believe it may be the same one as the CJ7.
BTW. I am now selling specialty tops. Even the new ones with zip outs. Will beat their prices :+)
Matt
Here is the cheapest full-length one I've found, if that's what you want/need.
Click it!
This one is made by Smittybuilt/Outland, but I think it's the same. The pic shows one for a late YJ with a family cage but it states that CJ/early YJ ones come with the rear support bows.
It's on sale for $61.95(74.95 w/ shipping), maybe more for AK. It's the best deal I've seen yet. I'm gonna order one but first I'm gonna see if they have anything else I need.
Anybody else done business w/ them before?
BTW, Matt, I might be hittin' you up for one of those tops in a month or 2 if everything goes well. ;)
