kohldad
- Goose Creek
- SC
Any special trick to bleeding the brakes with the Corvette M/C?
The original Corvette M/C had the brakes spongy so I just replaced. Made sure I bleed the new one on the bench till ALL of the air bubbles were out. This took about 15 minutes for some reason. Installed it on the jeep and started bleeding at the rear passenger brake. Had made several pumps before I remembered that I should have bleed the brake lines going into the M/C so jumped back up and bleed them there. Then went back to the wheels. Have run an entire quart of brake fluid through the system so any air in the lines should have been purged.
The pedal is very spongy still. When bleeding at the wheels, I have lots of volume at the rear, but very little volume at the front.
Could I have sucked a little air back into the M/C becuase I forgot to bleed the lines at the M/C first?
I'm thinking about pulling the M/C back off and starting over on the bench but wanted to ask for suggestions first.
