Bobcat made me do it
Cincyjeeprs
Cincinnati
Oh
O.K. So Bobcat said I needed one of these to remove rusty bolts, such as the Torx ones on the roll/sport bar (and everything else on this heap, LOL). So now that I have it, what do I do with it? Do I use the cutting tip to heat things up without...well...cutting? What should the flame look like for this type of operation - length, color, whatever?
https://www.mythermadyne.com/thc/en/US/images/thc/products/CS250outfit_hi.jpg
you definitely want to read the directions. You don't want the mixture too hot or you will cut through the bolts. The flame should be blue and not very long. You will have to play with the mixture to get the hang of it.
Need Help?
There is an "Expert" that lives in Cincy also. Just off of Norht Bend Road, not to far from you I believe. Goes by the name of "Super Sam". He can weld & cut ANYTHING! If you need me to, I'll put in a good word with him for you.:eek: :D :D :D :crazy: :wave:
HAHAHA :rotfl:
Yeah, but he is like the Proctologist. You have to schedule him 3 months out.:eek:
SO IT'S MY FAULT???:eek:
Once you learn how it's done you'll be glad you have it. It's amazing what you can do with a SMOKE wrench once you get it down pat. Sure saves al lot of time and frustration. I did finally got my trans pulled and in the hands of Mr. Beep to get overhauled for me.
Don
Don
Yep. Totally your fault. I told MrsCincyjeeprs that YOU SAID I needed one, and she said I should listen to my Elders.:bow:
HA! HA! HA!
Sounds like the pot trying to call the kettle black.
See, the trick is, you buy the Jeep for your WIFE. Then, whenever you need a part or a new tool for HER Scrambler, you just say "Only the Best for you, Honey".:D :D
Heck, even a little butane torch or mapgas unit does wonders in speeding up the disassembly process and saves a lot of bolts and hassle! I've been using a simple one with the screw on head for the small bottles and it's done a great job for me! Just can't get things cherry hot when you need to. . . .
I prefer the small 110 mig approach.
When the bolt heads start to strip out from rust just grind rust off, grab a grade 8 bolt, and weld into the depression.
The heat from welding and the new flats give you plenty of force to get that rusted stuff out.
Now if the whole piece is to far gone to save. the just break out the cutting torch and go to it.
Be careful though, it is easy to get carried away and start cutting out the good stuff. Before you know it you will end up with a bobbed rear bed....
Carl
