Bought My First CJ8 Today - Sort Of !!!
Major Jack
Zillah
Wa
Actually, I am buying an "8" from Toby with a fiberglass body. Not sure how I will like the glass body.
I found a really rust free tub that had been in a head on collision. The cowl was bad, so it was cut in the back part of the door opening. The frame was cut in the same place and is totally rust free also. I have a rust free cj7 tub and frame. Probably a lot of work, but I can see the two coming together to make a really nice rust free "8'.
I have done a bit of research. Have not had a lot of luck finding good info. Can anyone recommend links to folks that have gone before me? No use reinventing the wheel.
Thanks much.
Captain Jack
Congrats! Always read about the possibility to merge a -7 front and an -8 rear, but I can't recall ever actually seeing it happen.
Take lots of pictures for us! :thumbsup:
One of the members told me there is a thread on here somewhere that shows one being joined in the middle of the door. On the same thread it showed one being joined just behind the door opening. The second method being the preferred method as the doors should fit properly. He thought it was posted by Donaghy. I tried to search with no luck
there was a thread on Jeepsunlimited in the classic jep forum where a guy did that with some flatfender bodies so he could have a long wheelbase flatty, might take a look if you can find it and see how he went about it, the premise should be similar. Could also see if you can download AEVs brute kit instructions, or check for old Four Wheeler magazine articles on their tj brute project and see how they went about doing the bodymods there.
Also, be sure to look at Jeff's gaucho and retrowrangler threads on this site for a wealth of body modification techniques
