Brake Booster upgrade ideas?
After reading all of the successful booster conversions on the forum I decided I would go for it.
Purchased the booster from Morris 4x4, really nice kit, somewhat easily installed.
Like stated earlier definitely need to make/buy a grommet for the 2-1/8 hole left in the fire wall prior to bolting bracket.
Now the bad part, old brake lines will not reach to MC due to booster extending from firewall.
Uncoiled them and made them reach, but they looked really bad.
Bought new straight lengths of 1/4 and 3/16 tubing, flaring tool. The location of the proportioning valve and the interferences around it made this the worst part of the conversion. Got the old lines out and will fab new soon.
Really would like some suggestions on where to pull the vacuum from and some new air intake ideas due to factory breather will not fit with new booster.
1983 cj8
258
Off Road again in mine as well. Running 33” tires, inspection guy had me drive while he rode along, he asked “are the brakes good. He dang near hit his head on the dash ?
1983 cj8
258
I had the same problem with the lines. It is worth the effort to bend new lines for the new booster. Just take your time and make sure they seal well and don't kink. I pulled the vacuum from the rear port of the manifold. It took me two days of spraying PB blaster on the plug every time I passed my Jeep to make it release, but it made an easy release and thread on for the new port.
Do you have any pictures of the problem you are having with the breather?
Productive day, was able to get the brake lines bent and re flared to install the booster and proportioning valve fittings on to the tubes.
One note .. the reservoirs are opposite from the manual MC and the power brake MC, I'm assuming the larger reservoir is always tubed to the front disc.
The flaring tool will be going back to orileys .. you pay for what you get.. the 1/4" tube did ok but not the 3/16, it wouldn't pull down straight when in flaring tool. Will leak check them soon.IMG_1878.JPGIMG_1879.JPG
Update..
Managed to get brake lines finished, worked on setting brake pedal height. Found a lot of slop in the universe rod that ties to brake pedal and made a bushing to correct. Old M/C Rod had a 1/2" hole vrs the 5/8" of the new rod that came with M/C. Got vacuum tied in at rear of manifold as suggested. Will start bleeding everything and report on how it does.
Found an old single flare block and used the anvil with the double flare block , made a big difference. Made a cheap flaring tool a little bit easier to use.IMG_1881.JPGIMG_1882.JPGIMG_1883.JPG
Question..
Finally got back on scrambler brake project.
While bleeding brakes with the two man process, went to passenger back side first. Barely a dribble at that point, same at drivers back and very little movement in peddle when bleeder opens. Front bleeds fine with peddle going to floor when bleeder opens. Went with hand held vacuum pump to pull fluid to the back bleeders. Shouldn't peddle go to floor once back bleeders are opened?
I got a vacuum bleeder that uses air from my compressor. It has a piece that attaches to the bleeder fitting and sucks the fluid. It’s the best thing I’ve ever had for bleeding brakes. Makes it a one person job.
With rear bleeders Open paddle should go to floor (you pushing it, not on it's own). rears can be harder to get started (get fluid to start flowing). gravity bleeding can take some time, but usually works. vacuum hand pump can get things moving faster.
Thanks Jammer
I was thinking that the peddle should respond to the open bleeder. I was worried that a spec of dirt or trash got in the open port on the PV so blew compressed air in open back bleeders to open line at MC, then reversed air flow back to bleeders from MC.. got good air flow both ways.
Once I put the vacuum pump at back bleeders I did pull fluid , then tried pumping brakes and open a bleeder method. But very little response.. will continue today to see what happens.
Thank you for your response
JT
The vac bleeder has a cup that you have some brake fluid in to start. don't be afraid to pump the bleeder and fill the cup (just make sure you don't run the M/C dry). I've had to fill that cup 2 or 3 times. once you get a slow stream coming out of the bleeder screw, take the vac pump setup off and law gravity do the work. just keep filling the M/C..
Has anyone used the southwest performance brake booster conversion setup?
I was buying the Collins brothers conversion when I saw how much they charged for shipping AND charged me Texas sales tax, so I went with the unknown at southwest performance.
It has the brake line output on both sides of the master cylinder (which I'm not wild about, given its simply one more spot to leak) but otherwise looks to be very similar to the Collins unit. I figure worst case, I'll just buy a master cylinder at Napa and attach it to the kit from southwest performance.
I received the southwest performance kit. Looks very nice. I noticed what others have pointed out: the master cylinder is reversed from our manual one with the larger flare being at the rear- most cup on the master cylinder. Should simply be a matter of screwing them on to the opposite holes.
I'm hoping to do the swap soon so I'll update when I'm done.
I've installed the conversion kit. First off, it's a nice kit and would have been a very simple install taking about two hours start to finish. It would have .... had the chinese master cylinder not proved faulty.
In what was an almost erie premonition, the block off port was leaking air due to a nasty little spur on the threads I hadn't noticed. I could not get the front cup to bench bleed no matter how hard I tried, that's when I figured out the problem. It wasn't leaking fluid, just air. It wasn't until I put the brake lines on to get real pressure that I found the leak.
I wound up buying a '69 Corvette master cylinder from Napa which only has one set of brake line ports and seems identical. I'll put it in when I get home.
I was able to finally get the original master to bleed using jb weld, but I'll replace it nonetheless. If I did it again, I'd have jb welded those ports BEFORE I painted the master. After I discovered the leak I had to remove the master, clean all the bake fluid out of it and then seal it.
Just to add to my irritation, southwest performance parts wouldn't allow me to put a one star rating on their site....cheeky.
On the plus side, the brakes work amazingly well. I'm no longer scared that I'll be able to stop in time when a millennial texter slams on the brakes in front of me.
I just installed the South West Performance kit myself. Had issues with missing parts and they have not been responsive to my questions. Was the kit supposed to include an adaptor for the master cylinder to convert the deep bore to a shallow bore to work with the booster? My kit didn't have the inverted flare plugs or any adapter for the master cylinder and as received the booster will not engage the master cylinder do the bore depth. I have tried calling them and emailing them to figure out what I am missing but have yet to hear back. Any help you can provide would be much appreciated. Thank you!
The plugs came in the same bag as the little plunger which you'll need to engage the master cylinder. If they forgot that bag, you likely don't have that plunger. It's about 3/8" diameter and maybe 1.5" long. It slides into the bore on the POS master cylinder.
I had no luck getting replies from them either.
Hey guys, I have a Navaho Booster on my Scrambler and the first one failed. But, we don't think it was a fault of the booster.
I have a 383 made from a '72 block 350 and while it does have a new Edelbrock manifold, the tech is a lot of 1972 tech. About that time GM was sued by Corvette owners for failed brake boosters. GM responded with a brake booster line filter to prevent / reduce the fumes breaking down the rubber diaphragm inside the booster.
https://www.summitracing.com/parts/rnb-80195
I put one on my new booster after the old booster died. Still works, so maybe $8 in prevention wasn't too bad.
