firemanhank
- Ooltewah
- tn
I installed a 4 inch BDS lift. Went to change the brake lines and found 21 years worth of torque on the brake line nuts. Now, they are stripped to &$%#. This is after much liquid wrench. I need to replace the front lines from the brake lever at the frame rail to both front ends. Is there a certain aftermarket kit with the proper bends, or can I just buy stainless and route it clear of obstruction.
Also, does anyone have 15 X 8 rims they want to sell?
Just tryin to get my jeep ready for Wndrock. Got the lift--still lack axle buildup and tires/rims.
BigWalton---I know you have a BDS suspension. Was your rear end a tad lower than front? Did you have to add a leaf? Mine sits a little lower and I don't think it is because of full hard top. Maybe I will go with a slighter larger rear shackle.
Hank
Hank
