They protect the radiator and grille, true, but their intended purpose is to keep you from nosing over in a downhill situation. You can build a radiator hoop that is upright.
Poison Spyder sells a rear stinger/tire carrier that I think is awesome.
Looks good Scott. However, like Bones said, to do it properly, it needs to be gusseted. So if you need more projects for the bender, bend some tube fenders, and then tie the stinger into them, then into the engine cage, then into the full cage, and then into............
