Calling all trail guides...
ScramFam
Registered User
Nowhere
OH
Hi guys. I'm getting ready to write a series of feature stories for the SOA Web site. One of the first stories will be on trail rides. It will come in two or three (maybe four) parts.
1. Preparing for a trail ride -- preparing your vehicle, what to bring, what to leave at home. how to choose the right trail for your vehicle...
2. On the trail. Safety. Things you should NEVER do. General how to's -- climbing rocks, mud, hills, sand, water...
That's where I plan on going. Please let me know if I'm missing anything.
In order to write something worth reading I need your help. I am far from an expert off-roader. Most of my off-road experience have been expensive lessons. Soooo, I'd like to use and quote our resident trail guides throughout the story. Also, I'd like lots of photos to help illustrate the points. If you're willing to be a SME (Subject Matter Expert) please let me know.
FYI -- One of the next stories is: How to find, buy and retrieve a Scrambler. I'll need lots of SMEs for that one too.
Cant wait to hear what you've got!
How to find a scrambler:
1. Ask everyone you know.
2. Get a sore neck from trying to look on both sides of the highway at the same time.
3. Do countless u-turns to go back and look at the jeep you thought was a Scrambler in the quick glance you got.
4. Bang on countless doors asking if they know who the owner is.
5. Look at several only to find it isn't worth saving.
6. Hide you excitement from the owner when you find an almost mint one.
7. Buy it before the owner realizes what he is doing.
8. Get it home.
9. Brag about the good find and cheap price, must be both because you did buy it.
If you want any other info like this, or want someone to review the articles, just shoot me an email.
Rule #1 BE PATIENT... the right one is out there. It will find you, or you will find it, if you rush things, you WILL pay MORE and get LESS...
How to find a Scrambler:
Method 1: Hang out with JC. He seems to be finding a lot of them lately, and he has to be running out of space to keep more for himself. :D
Method 2:
a) Comb the local newspaper classifieds, Jeep classified sites, AutoTrader.com and the cj-8.com forum. Ebay is typically a good buying/selling venue, but Scramblers usually pull a premium price (good if you're a seller...bad if you're a buyer). Also comb the countryside, hoping to catch a glimpse of that utopian low-mileage, farmer-owned Scrambler.
A couple of thoughts on this:
1) Preparing for a trail-ride begins AT HOME, in the garage. There are LOTS of little things that can be addressed at in just a few minutes with the proper tools in a shop that would be show-stoppers on the trail. Before every trip "pre-flight" your Jeep.
2) Check ALL fluids... Are they topped up? Are they "healthy"? Do they smell burnt? Are they milky (water contamination)? Do you have spare fluids?
3) Check hoses and belts... Are they dry/cracked/spongy? Do they need replacement? do you have trail spares for critical hoses/belts?
4) Become one with the greasy side of your Jeep... This is something of a gestalt thing. Every one of our Jeeps is different. Get under yours and look around. Get a feeling for what is "right" and what is "not right". While I'm not a freak about cleanliness, a chassis devoid of crud will allow you to determine where any new leaks are coming from BEFORE they become problems. Check your driveshafts, do they have un-due play? How do the joints look? Check your steering, any excessive play, do the tie-rods and drag-link look OK (straight, un-damaged), is there any undue play in them?
5) Lube it... While you're under your pig take a grease-gun with you. It'll only take a few minutes, but shoot some grease into those zirc fittings for your steering, driveshafts, and u-joints. Fresh grease is a good way to keep OUT contaminants. Also a good idea to lube it again when you get back, especially when you are in deep mud, sand, water, or other contaminent.
6) Check your vent lines. Tranny, Xfer, axles. Are they in good shape? Are they still up high? Connected properly? Clamped? A ventline can save (or kill) your tranny).
I'm sure there are others, but that's what I have off the top of my head.
Long before the trail ride start collecting spare parts.
-Most likely if you break it someone will be able to help you,
-BUT I like to pack 'as if' I'm going alone
-Try to think through what might sideline you, buy accordingly:
a spare (old) set of plug wires & cap
a spare (new) starter solenoid
I pack a used set of manual locking OEM hubs I bought on ebay for 10 bucks & also a used rear drive shaft I'm currently refurbishing complete with new U joints & new straps
Then organize & secure all this stuff so in case of a rollover you don't have ammo cans denting your noggin
Check your fire extinguisher
Refill your 1st aid from the band aids, tylenol & bug spray you used on the last trip
...a gestalt thing
is that like a warm & fuzzy feeling:D
I've always done this too bluesman2a!!
Slide under your rig & look at all the areas you've worked on recently, now torque down the bolts & nuts-
Then look at the areas you haven't worked on in awhile,
some of those probably need a bit of torque too.
ps- good thread, can't wait to start reading some of these stories
trail ride
Everything I've learned about trailing, I've learned here! I hope it helps with your article, Matt.
1. Find a Scrambler (see future article)
2. Pay too much for a car that old.
3. Replace everything that works just fine.
4. Shave your rear end (I think Mules calls it "bobbing")
5. Big ole tires help
6. Meet with your buddies, go in the woods, break stuff, piss, moan and take pics so the rest of us who dont have the opportunities to break stuff can live vicariously thru you, fix stuff, and go find your buddies again, break stuff again, etc.....
Lemme know if I missed anything important.
Scott
PMS What did you expect from a stocker???
THE MOST IMPORTANT RULE OF ALL!
You got to have a good sense of humor and if your going to take it offroad then expect to get some damage!
Next Rule...........Don't whine about the above.
The last rule.........It's not if your going to roll it,but when and how often
Above all and the kidding aside the top rule is to "BE SAFE" prepare for the unexpected and return home in one piece!
JC
