Can't Buy It so I Built It
TheDustyRag
Member
Pittsburgh
Pa
Well maybe not built just yet but I'm building it now! I'm here to finally start a build thread. I posted in the lurker thread a while back but am now just getting around to starting this. I've been working away at the body work and have made some good progress. I wish I would have started this earlier but better late then never. I'll try and sum up where I'm at so far and what my plans are for the build. Please feel free to let me know what you think and if there's any advice you can give. I'm no master craftsman when it comes to restorations but it is something I love to do in my free time. I've done some body work in the past fixing floor pans, rocker panels and helping my dad with a restoration but this is my first full on build from the ground up. I've worked really hard to get to a position where I can finally do my first build and I'm stoked it's an 8! My plan for the scrambler is to build it mostly stock looking with a modern drivetrain. No extreme rock crawling planned for this thing but I do plan to use it a lot. And by a lot I mean I want to drive this thing everywhere, in all weather conditions, camp, fish, and explore the wilderness. I am hoping the rig will last me many years/miles and when it's all tired out I'll build it again.
What I've got so far / how I bought it:
1981 Scrambler
Sherwood Green Metallic. Code C1
No Engine or Transmission
Dana 300
Rusty but fixable body
Rusty Frame
Good floor pans and bed
Narrow Track 3.31 with Trac-loc
So maybe not starting with too much lol. But that's ok, I'm planning to replace most of this anyhow. If I started with something complete and in great shape I'd be more inclined to stick to originality. It'll make more sense when you see my goals below. In all honesty though, I'm just happy to have found a scrambler at all.
Goals:
Engine - Cummins R2.8 turbo diesel engine
Transmission - TR-4050
Transfer case - Keeping the Dana 300
Frame - Throttle Down Kustoms (Ordered and on the way!)
Axles - Wide Track Dana 30 and AMC 20. (Traded some old XJ parts for these. Has a Detroit Trutrac but only usable with the 2.73 gears)
Lift - I'm thinking 2.5 lift. Probably YJ OME. (Suggestions would be awesome)
Tires - I am thinking 31x10.5r15. I was planning 33x10.5r15 for the longest time but the more I think about it I like the 31s more and more.
I've got tons of other thoughts and ideas I keep bouncing around for the future for this thing. Like building a custom rack for a rooftop tent, building a hardtop, or going crazy and building a truck top camper to fit the whole family someday. But for now I just want a good traveling mini truck I can put the miles on that'll get me to a cool camp site and I'll put up a tent when I get there.
Anyway, here's some pictures of when I got it and of the progress so far. I've cutout and replaced a couple body mounts, replaced a floor support, put in new toe boards, and painted the underside front section. Cutting out the rot in the rear area now.
Feel free to ask me any questions you may have about the build or what I've done so far. I plan to be as active here as possible.IMG_2818.JPEGIMG_3316.JPEGIMG_3378.JPEGIMG_3520.JPEGIMG_3603.JPEGIMG_4206.JPEGIMG_4207.JPEGIMG_4243.JPEGIMG_4664.JPEGIMG_5452.JPEG
Also, I've started an Instagram which I'll post progress more regularly but with less explanations. It's @overlandcj8.
Lastly, I can't say enough how stoked I am to be here getting to do this build and thankful for all the posts you guys have made already. The history of posts made by this community has already helped me out a ton with my build progress and decisions. You all are truely great. Thank you!
This is going to be a fun build to watch. Congratulations!
I've been getting some time to move things along here lately. Nothing transformative just yet but I'm closing in on finishing the bottom rear section. I've spent a considerable amount of time fixing all the little bad spots in the bed area. I've gone over everything with a wire wheel and flap disk to clean up any surface rust and exposed any weak areas. I've cut these weak spots out and replaced them with new sheet metal. I wasn't able to save the passenger side wheel well but the driver side was in good enough shape to only have to replace a couple spots. I also cut out and rebuilt the back section of the bed where the new tailgate end body support goes. I have the new support lined up and ready to put in but haven't just yet.
It's been really cold here in PA lately and I'm having a hard time finding kerosene near me. Only place I know of to get it here in Pittsburgh is closed on the weekends now because of COVID. I want to paint the inside of support before putting it in but with the cold weather and no heat it might have to wait until it's a little warmer. As soon as I get the support in and the underside painted I'll be flipping her right side up again.
Although body work is endlessly captivating stuff and I could go on forever about it. I do have some other news I'm really excited about. I just placed my order for the engine and transmission! I ordered the Cummins R2.8 turbo diesel and Tremec TR-4050 5-speed manual transmission from Quick Draw Brand. Man it feels good to finally pull the trigger on something this big for the build. I had been planning to use this engine ever since it came out a couple years ago. It just seems like to best engine for my plans for this jeep. The TR-4050 is a great looking transmission too. That 6.16:1 first gear is just too good to pass up. I kept going back and forth on a combination of a few different options like using a 99' VW TDI (offered to me free, needs a new head), 69' ford 302 (Already have, needs rebuilt) or the seemingly legendary AX-15 transmission. All of these options would have been awesome. But when I looked into it more, buying a brand new R2.8 and TR-4050 just made too much sense. I spent a ton of time considering the pros and cons of all these options, I even made spread sheets, so if anyone has any questions on why I went this route don't hesitate to ask.
Here's some pics of the progress before I grind down and clean up the welds.IMG_6123.JPEGIMG_6124.JPEGIMG_6118.JPEGIMG_6117.JPEGIMG_6103.JPEGIMG_6100.JPEG
I seriously considered going the 2.8 route on my build, looking forward to seeing how your setup works out. Personally, I'd do the OME 2.5" & 33's...it gives a slightly beefier look without going extreme...heck, that's what I did...lol
I really do like the look of the 33's especially the 33x10.5's. a 10.5 wide tire just looks more vintage to me. I'm honestly on the fence still. 31's seem like they "fit" the jeep and look more period correct IMO but I agree 32's and 33's add a little extra beef, which I also like. I've scoured the internet more than I'd like to admit and I've seen pics of each tire/lift size that all look good. I think it has more to do with getting that lift to tire size ratio just right. But honestly, it'll probably just come down to what I'm feeling the day I pull the trigger on tires haha. I have a set of 235/75r15's (about 29") on original CJ wagon wheels I'll be using for initial testing. As well as a set of 31's that were on it the day I brought the jeep home. They're pretty dry rotted though so I don't plan on actually driving on them, but they'll help me make that decision once I get the body on a rolling chassis.
33' are kinda period correct. In 1991 my sister had a 85 CJ7 Laredo on 33" high rollers. They were huge at the time for a CJ. The tires where put on the Jeep in the late 80's. Period correct enough???
I can't argue with you there. 33's have been put on CJ's for a long time and definitely fit the part too. I think the real issue is I just have too much time to decide. It doesn't really change much between 31's to 33's as far as gearing/price goes. I should have my frame by end of March/Early April. I'll order the suspension parts and body mounts then. From what I've read on here I understand it like this, the OME 2.5" lift is good for 31's but adding a 1" body lift allows you to clear the 33's well.
This is going to be a great build! I can’t wait to see it come together.
That TDK frame is the only way to go on a build like that. It’s so much stronger than the stock. I went with Alcan’s springs with a 4” lift. I plan on running 35s so I did a shackle reversal on the frame from TDK and had Alcan shift the axle forward an inch to better clear the 35s.
Nice, this sounds like an awesome build. I think the stock frame would have been ok if the rust wasn't so bad. It might be fixable but I just didn't want it to be a worry in the back of my mind. I feel much better knowing I won't ever have to worry about the TDK frame in any way. Anyone want an 81 scrambler frame? You can have it for free if you can pick it up. I took lots of pictures of the inside and out if interested.
I've heard great things about Alcan springs too. Did you have to take your jeep to them in Colorado to get the springs made?
No, I worked with Bill over there and he based the spring design off the specs that I was building too. 360, 35s, winch, etc. I also went with the orbit eye shackles that are supposed generate more flex with less bind. We will find out. Here's a link to my build thread.
I had Alcan make me a set for a CJ5 I had loved them.
