CB antenna mounting locations?
Alaskan Postal nutjob
FORUM MANAGER
Ok, if I don't get my outboarding brackets assembled for this weekend, I'm going to be doing some non-essential tasks because I've gotten most everything else taken care of to get it running for inspection without the axles being hung...
One of those is mounting a new Firestick 4' antenna somewhere. Before I start drilling holes, does anyone have ideas about better places to mount it?
The set that I got came with a Firestick mount that's one of those 90 degree deals that should mount to the side of the tub.
I guess that it's supposed to be as high as possible right? I'm sure it shouldn't go on the side... to the left of the brakelight next to the tailgate opening?
I was thinking about mounting it to the bumper, but I figure it's too low...
Any other suggestions?
Mine is centered on top of the original tire carrier, which I don't think you have. Anyway, what I wanted to add is go to a truckstop; they have a wide assortment of hardware. You can add a spring and/or a quick disconnect.
Mine is on my spare tire carrier too.
For the best radio performance you are right: as high as possible and in the center of the top. The vehicle body acts as a gound plane for the vertical antenna.Picture a base station antenna. Of course the first low branch will take it off :( Rear bumper would be good or if you don't mind drilling holes; up alittle higher on the back of the postal. Maybe, on the cowl opposite side from the am/fm antenna. You might try a magnet mount in different places to see how the radio works before drilling holes.
I mounted my 8 foot whip antenna on the chrome, tire swing bumper bracket.
attachment.php
If you don't have the tire mount, then you could use the two holes where the upper right (or left) bolts are located. These are the same bolts that hold the diagonal brace just outside the tailgate.
Thanks guys... I don't have a tire carrier and I don't really have plans to get one. Now that I have the Crusher corners, I figured I ought to bolt it to that as one of those is a SERIOUS chunk of metal for the ground plane.
I had to get over the idea of drilling holes in the tub. Heck, rust has already done it's job, so in mounting the rockers, corners, LEDs and all, I've drilled MANY holes and BFH'ed the thing plenty :D You should see what I did to be able to recess the LEDs :D :D Booty fab BFH bodywork baby!!! :D
I already have a spring that screws into the mount on one end and antenna on the other.
Eric, I think that suggestion to try the upper holes for the spare tire mount (I don't even have the lower ones, there's holes in the corners there, but not in the body) is a good one. That will mean that I only need to put one other hole in the corner/body and that's about as high as it gets. I just don't know how much the reinforcement on the inside of the tub will bother that spot...
antenna
The mounting of the antenna would be best on a large metal plane but for CB it's just fine mounted on the side. You're pretty short distance for broadcasting with the CB. I've got mine mounted on the rear side of the tub and I have my Ham radio antenna mounted on the other side. They both do fine but for the longer range broadcasting I'm moving the Ham antenna to the rear tire mount, just a little higher.
I've been giving this some thought too...
As a former truck driver, I have an affinity for my ol' CB radio....As the other guys have mentioned, the best place for it is high and toward the center. However, for the purposes of a trail radio, it won't be doing you any good if you scrape it off on a tree limb. For the most part, you'll prolly just be using it to communicate with people in your immediate group, so mounting in a lower/safer postion would probably be a wiser move.
You could mount 2 bases on your Jeep, one low, one high. then just move the antenna as the need arises. This is what I plan on doing, since I have an extra mounting base leftover from the dual antenna set up I had on my last truck.
Bill, it's good thing you're a former truck driver. It's takes a fair size rig to haul 2 Scramblers :D .....
