CJ-8 Acquisition
yaHEARDme
I am in the process of procuring an 85 Cj8. I was wanting to know how these do with the stcok drivetrain. Does the engine power this jeep fairly well? Any common problems I should know about? I would love to make this thing a beast, but due to $ I'll probabally do a 4" lift with 33"'s; if I even do that. Are all the axles and transmission fairly reliable? I am mainly looking for something that will be driven on the street, and occasionally(couple times a month) in the mud/light trails. Any info that could be offered to a soon to be newbie would be greatly appreciated. I am wanting a reliable four wheel drive that I can have fun with.
Thank you
Well, the reliability varies from vehicle to vehicle (depending on previous owners, previous use/abuse, quality of mods, and upkeep, among other reasons) but IMHO you couldn't pick a better 4wd to have fun with! They are great for wheeling, on-road ride, and towing due to the longer wheelbase, and you can configure it however you want - from pickup to seating for 6, from full hardtop to no top, etc.
Does the engine power this jeep fairly well?.... I'll probabally do a 4" lift with 33"'s
I've only had 6cyl engines (258 inline six), which powers jeep fairly well. However, if you plan to put 33s on the vehicle, you may want to plan on a gearing swap. Browse the forum for discussions on figuring out your current gearing, trans, and engine, and where you want to go from there. Be careful of the dreaded "incrementalism" or you might J.ust E.mpty E.very P.ocket.
Congrats on your upcoming purchase and we look forward to hearing more from you!
-Mike
Do you know the stock tire size? I wouldn't think that 33"'s would justify re-gearing. Are the stock tires that small? Anyway, thank you for answering some of my questions.
the info you need to know
Ok, here is the scoop-you got a great platform to work with-the first thing you need to do is make sure the front end and mechanics are up to snuff,then invest in a set of 1 piece rear axles,these are usally in kit form and you usally get what you pay for so invest in the good ones,the stock axles are two piece with a spline hub that is held on with a "big" nut on the end of the axle shaft and it's not if you break them but when,because you will break them!The AMC 20 rear is a good one if you don't plan on doing any jumps or monster truck impressions,it has a huge ring and pinon gear,larger than a 9" ford,the axle tubes are to weak for jumping and hard core rockcrawling and you need to have a couple of rosebud welds put into the housing to keep the tubes from turning under hard use,If you are planning on running a 4" lift and 33" tires plan on a regear,most stock axles are 2:72s so they are way to high for 33" tires unless you like to shift and get passed by everyone:( I'd go with 4:10 gears with the six and 4:56 if you don't do a ton of hiway driving-as far as the motor there is a ton of up grades for the stock 258 six,a lot depends on what you can do as far as emmisions in your state,My advice before you start any major upgrades is to read,read,read,READ and get as much knowledge as possible,ask a ton of questions and then ask them why they did what they did,then ask them what they would do differant and why,and ask as many people as you can,go attend a local 4wd club meet or even better a trail ride to see what works and what don't:D take pictures and notes,you can never have to much knowledege and knowledge will translate in to money saved,belive me,i know from experience:rolleyes: -hope this helps and answers a lot of questions-JC:D
it depends on the axels, the most common ration was 2.73 and that ok with 31s but sucks with 33s. 3.31 and 3.54, 3.73 and 4.10 were the other options. If the gears are stock the front dif cover should have the ratio stampted into it. for some more referance on the axels and ratios check out http://www.jeeptech.com/axle/
Well, I plan on going to look at it tonight. I hope it is in as good condition as this guy says it is. I just hope I won't be getting in over my head. I really appreciate everyone's help with answering my questions and offering suggestions.
Thank you
JR
I also have tried to make my Scrambler capable on road and off. As some of the members of this board can tell you, I have made many modifications that have resulted in a very good on-road vehicle, still a pleasure to drive. JC's right, the first thing to change is the one-piece axels in the rear. If you decide to go 33's I would seriously consider changing your axle gearing to 3.73 or 4.10. I currently have 33's and 4.10's and on the road it's a little high, I would go to 3.73's if I was sure 33's were the largest tires I would need. It also depends on the trans, high gear 1:1 or do you have/anticipate an overdrive?
Also, I live very near you in Napoleonville and your welcome to drop-in or call (985)526-1199.
Good luck with the Scrambler.
Tim
Tim,
Well I went last night and looked at it, it wasn't quite in as good condition as I was told, not for $4999. There was some frame rust that seemed like it will be too expensive to attend to. So it looks like I'm scraping the Scrambler idea. I doubt I'll come across one anytime soon and it turns out I'm not built right for a scrambler. I had also been looking at a 79 FS Bronco that I might turn to. Who knows. By the way, I live in Baton Rouge, not too far away. Do you know of any good places for trails or mud? Preferrably legal.
