the info you need to know
Ok, here is the scoop-you got a great platform to work with-the first thing you need to do is make sure the front end and mechanics are up to snuff,then invest in a set of 1 piece rear axles,these are usally in kit form and you usally get what you pay for so invest in the good ones,the stock axles are two piece with a spline hub that is held on with a "big" nut on the end of the axle shaft and it's not if you break them but when,because you will break them!The AMC 20 rear is a good one if you don't plan on doing any jumps or monster truck impressions,it has a huge ring and pinon gear,larger than a 9" ford,the axle tubes are to weak for jumping and hard core rockcrawling and you need to have a couple of rosebud welds put into the housing to keep the tubes from turning under hard use,If you are planning on running a 4" lift and 33" tires plan on a regear,most stock axles are 2:72s so they are way to high for 33" tires unless you like to shift and get passed by everyone
I'd go with 4:10 gears with the six and 4:56 if you don't do a ton of hiway driving-as far as the motor there is a ton of up grades for the stock 258 six,a lot depends on what you can do as far as emmisions in your state,My advice before you start any major upgrades is to read,read,read,READ and get as much knowledge as possible,ask a ton of questions and then ask them why they did what they did,then ask them what they would do differant and why,and ask as many people as you can,go attend a local 4wd club meet or even better a trail ride to see what works and what don't
take pictures and notes,you can never have to much knowledege and knowledge will translate in to money saved,belive me,i know from experience
-hope this helps and answers a lot of questions-JC
