CJ8 Project Daily Driver
gmellison
Ojai
CA
Hey all. I finally got my Scrambler and working on my pseudo resto-mod build. It's already my daily driver so my improvements get done on my few days off.
What it is:
1983 with a 258 straight six and T-5 transmission. Dana 30 front, superlift hubs, and weak 20 rear, one piece axles though. Rebuilt engine, trans and Dana 300 transfer case. Half cab with bulkhead and no visible cancer, only surface rust so far. Mopar Performance MPI installed and working, although I need to change tach. A/C came with it but needs to be installed. For the most part a stocker ready for my build.
What it may become:
It will be my daily driver so anything done will need to be mild for now. I plan to clean it up and make it trustworthy, as much as a jeep can be.
Back seat for the kids, two boys, and a full cage for safety. But want the ability to reinstall bulkhead and half cab in future.
Mild lift 2" for now, free from friend.
New bumpers and full hard top.
Eventually a new paint job but not a priority, after all I plan to wheel it a bit too. In the future more radical improvements but for now, I'm just happy to finally have her.
I'll get pics up and keep you all up on her progress. I appreciate your comments and any advice for this rookie.
Pics from the seller and the day I bought her. I got her from a guy named Walt from West Coast Willeys. Nice guy and pretty knowledgeable on jeeps, he knew what he had. It was 700miles away but well worth the drive.
Sweet!
Looks Nice!
Nice looking Scrambler! BTW, that AMC 20 is not weak, in fact with those one piece axle shafts, it is as strong if not stronger than a Dana 44. The housing is weaker but the Ring and Pinion are stronger.
Polorfire is right. All I have read suggests the AMC 20 can be built to a very durable axle.
I just picked up a empty AMC 20 wide trac to build.
Skip welding tubes to housing.
Cap top of tubes.
Truss
Ecked Locker
New 3.73 gears
Warn Axle Kit
Disc Brakes
I have slowly purchased the above and am now ready to build. I didn't want to tear apart the existing rear with less than 27,000 miles on it.
Thanks Polarfire and Captain Jack. I figured with the one piece axles I'd be fine with the wheeling I'm planning on doing. I was planning on running them till the break which may not happen. I'm happy to hear they're stronger than I thought. Capt. Jack, are you building it for a back up or just improving what you have?
Clean looking 8 I just picked up a CJ8 Laredo a few months back that has the same chrome tie downs that yours had in the same location interesting :)
Mine is a Postal with 2.73 gears and automatic. Not the best combo. Here's what's happening.
AMC 20 as described.
AW4 overdrive automatic
Mopar EFI
Dana 300 with Lomax 4:1 gears.
3.73 gears and automatic will be good for highway cruising
3.73 gears, Ecked lockers front & rear with the 4:1 will give the low gears for offroad
I am looking for a wide trac Dana 30 to build. This is the last major part I need. Everything else in on hand and ready to go.
Although, I wouldn't mind finding a Dana 300 transfer that needs rebuilding and keeping my low mileage 300 from the Postal. I just can't bring myself to tear apart running gear with less than 27,000 miles on it.
I
Captain Jack,
It sounds like we'll be running similar setups minus a few things. Let me know how it goes. I know what you mean about tearing into young running gear. I believe in "if it ain't broke, why fix it", so i usually find a way to break it.
JeeperTim,
I'd like to see some pics of your Laredo. I wasn't feeling the tie downs so they were gone fairly early.
I'll get some pics together and bring you all up to date on her progress.
So far I installed:
New alternator and belt,
New red top optima, still need a new battery tray though,
Replaced stock plastic valve cover with aluminum one, just found a new leak from it tonight, yay!,
Bikini top and half soft doors, needed soft top rail and new latches for doors,
Removed tonneau cover and chrome steps,
Welded up holes from snaps, tie downs, steps and PO hack job on floor for passenger seat (first time welding),
Treated bed rust and prepping to line the tub this week. I'm going to try Al's Liner. It was written up in last month's JP magazine and sounded good.
And a new rear Corbeau fold and tumble seat.
I'll let you know how the lining goes, but for now, check out the glamour shot the wife took. She makes it look pretty good.
Do you still have the tonneau cover? If you are getting rid of it (I assume you are since you welded up the snap holes) I would be interested in it. PM me if you are. Thanks.
Got the new exhaust in. New cat and muffler, magnaflow. The tail pipe looks a little hokie for my taste and may need some help but it sounds loads better. No more rattling loose exhaust hitting the tub, and it's got a deeper tone. Haven't noticed any more power yet.
Started lining the tub. I got two kits of "Al's Liner" black and the spray gun. I spent the last two days prepping the tub and ran out of time today, wound up rushing to get it done in the dark. I knew better but did it anyway. The air compressor tripped the breaker, thank the kids for turning on all the lights and I have yet to rewire my garage. Lack of light and drop in pressure lead to a poor spray job. I decided to stop and try to fix it in the morning with the other kit and more light. We'll see but I fear it'll bug me forever.
So three beers for me and five pics for you. I'll update y'all tomorrow.
Spray liner done with Al's Liner. I was able to see my mess up and fix it in the morning. Good coverage and I like how it turned out. I did learn some lessons:
Add some flattener, it has a very glossy finish
Very little trigger is needed on spray gun. It got globby quick.(is globby a word?)
And I remembered other old lessons learned:
Don't rush, you can always move your deadline
Don't shoot in the dark, even if you have every light you own on the project it's not enough.
In all it's not too bad for $250. And I'm sharing the gun with my buddies.
I know what you guys are gonna say: "should've painted outside first"
And I agree. The outside wasn't too bad but the inside had rust starting and I wanted to take care of it before winter. Besides, I still don't know what color I want, all I know is it'll have black interior.
Any suggestions?
Silver, gun metal gray, maroon metallic, copper brown metallic, chestnut brown metallic and black are all on the list.
Looks like you had a pretty solid Scrambler to start with! Before you get to far along I would pull the roll bar out of the Jeep. There is bound to be rust under it on the floor, even if it is just surface rust since there was no paint from the factory under the roll bar. Out of all my Scramblers I have yet to have one that didn't have at least a few spots of surface rust. Plus, its a good time to replace the torx bit bolts with normal grade 8 head head bolts to ease roll bar removal if you ever have to in the future. I would also remove any other bolts, such as the tailgate cable support bracket bolts, transmission tunnel cover screws,etc, and install new or clean up the old ones and reinstall in case these ever need removed.
As for installing liner before painting, it does make it much more difficult to paint, especially if you spray the liner over the tub side lip. You could always remove the liner from the tub lip when painting and then just respray the liner on the tub ledge again afterwards. On my Jeeps that had any signs of rust, I just treat the rust with Eastwood's rust converter and encapsolator products or POR15 (I personally really like Eastwood's stuff, especially the aerosol cans for spot rust treatment!) and don't install any liner until my Jeep is either painted or I decide not to go with any liner and use just paint. That way the rust is no longer an issue and I don't have to be concerned with lining the tub before it is painted. Or I can go back with just paint on the floors and underside if I decide to not go the spray in liner route. Plus, it saves the hassle of trying to remove the liner if I decide to remove it to go back to painted floors and underside!
Color is a tough one! Are you going with original seats and interior? I personally would stay with black if that was the original color and you are going to run a black interior!
JS, I agree with you, except she still is a nice solid jeep.
My original plan was to remove the rollbar but after breaking every Torx bit I own, even after soaking them in Wd-40 and using heat, and running out of time I decided to go ahead with it in place. I'm planning on going with a full cage next summer and will be cutting out the roll bar then.
All rust has been treated and I'll take care of under the rollbar plates when it gets removed. I used a different product but like the Eastwood stuff and will probably try that next time.
Supposedly this liner is easy to blend and patch but we'll see.
I plan to use this jeep as a jeep and not a show or garage queen so the durability of a liner was important to me.
I put in the 2" lift and like the height but not the ride. Already planning on a YJ 2.5" lift next summer as well.
Running out of cash so progress is going to slow down, until I can sell some of my extra parts.
I was planning to install my stock radio in my "uncut" dash but found it'll need some work. Bumming about that.
Here are some pics, lift pics will be up soon, and I appreciate all advice and comments. I can take it. Thanks you guys.
This last week I found my fuel gauge is off, 1/4 tank = empty and late for work, Kragen O'reily alternators are junk, late for work again, and even though I put the half cab on to protect from rain I can still get wet, leak from windshield rubber.
Question:
How do I adjust the gauge or sending unit? Not a big deal to fill up before 1/4 tank but I'd like things to work right.
Pic after lift and reinstalled cab. I'm digging the pick up again.
That's my beer on the fender after waxing the DW's car.
