Come-along recommendations?
1x1_Speed_Craig
Simplify...
Greeneville
TN
After reading bluesman's CJ-10A pick-up story, it got me thinking about my need for a cheap "Bail me out of a stuck situation" tool. Family members have been asking me about gift ideas, and while a winch isn't in the picture (either as a gift of me buying one myself), I thought a decent come-along would be nice for the trails.
Recommendations for good ones (and stores) to look at?
Thanks,
Craig
I can't remember the brand of mine, but don't get suckered into some cheap trailer load sale one.
The extra money up front is well worth it!
I've had mine so long, that I am sure what I paid is out of date!!
I would suggest the best is to check at Lowes or Home Depot. I think they have some decent ones.
There is/was a really good one that we bought at a place I worked at in the '80s that was by and far the best I have ever seen. It was over a hundred dollars back then.
I will look in my shop tonight and see what the brand of mine is.
Well, I'd be interested in GOOD ones too... Can't tell you where to find them, but I CAN tell you they are NOT at Harbor Freight!!! :eek:
Hi-Lift Jack?
Can't you just use a Hi-Lift as one? Dual purpose, $60. I think they carry them at Tractor Supply.
Mat - I actually already have a Hi-Lift. I was looking for something that I could wrap around a tree and pull myself out with.
Come-a-longs
Both of ours date back to when my grand father was in the coalmining business! Check indusrial supply stores and suppliers. Remember treat a come a long as you would a electric winch, The loads that we but on these thing in vehicle recovery are scary. You are only as safe as your weakest link. Be that a attachmet point, clevise, wire rope or cheap chineas torcher device er come a long. A really heavy coe-a-long is marketed uder the man on more power puller in most 4WD magazines. Incidentally A nice heavy 10ton come-a-log fits very nice inside a deep (double depth) 50cal ammo can.
Thanks guys. Mules...that is one BEEFY looking unit. Now the question I have is the model. They have 2-ton and 3-ton units, with the 3-ton available with only 20' of cable. Would that be enough? The 2-ton models offer up to 35' of cable.
TexasAg77 - Let me know what brand yours is if you get a chance.
Thanks,
Craig
The 2-ton version will be more than adequate.
I purchased a 1-1/2 ton with 20' cable from lowes. I have pulled a F350 CrewCab 4x4 that was buried to the axles in black goo with one. Would put as much strain as possible on the truck then get in and hit the gas. Would get about 4 to 12 inches and then repeat the process. Slow going but after about 30 minutes, had moved the truck 20' to unstuck position.
Then carried it in my Warn equipped Grand and used it on several occasion to pull myself out backwards when a forward recovery was not possible. Haven't carried it in the Scrambler yet since I only ride with friends that have winches. But once I get it to a semi-daily driver and start exploring on my own again, will start carrying it again.
Do the trees and your cable a favor. Put a tree saver on your wish list. Wrapping the cable around the tree and back to itself will cause a weak spot in the cable where the hook is. Also, the cable will cut into tree and kill it at that spot creating an open wound in the tree. It may only look like a small depression when you take the cable off, but it is a major injury. Also, carry one or two 20' straps to extend the range of the cable.
