84 258 6 cyl
I have a re manufactured engine, never been out of the driveway. It is getting cooling water in the engine oil. It is under a warranty for parts. I got a new head gasket and pulled the head. The old gasket looked good and did not really show signs of it leaking. Put in new head gasket and it is getting water in the oil again.
It has good compression in all cylinders between 152 and 155 for each
It runs perfectly and starts right up, but radiator water is getting in the oil, it is milky again and went from low to full on the dip stick after running it a few times. When I put new oil in it I purposely left it a quart low.
Any help on what could cause this. A warped head? A cracked block? can the block crack and leak water into the oil with no impacts on compression? Could it have overheated? It has never run for more then a few minutes at a time and never run without water and oil of course, and it has a good water pump.
Would like to know possible causes and fixes before I go back to the auto store. My fear is they will say it overheated and not covered.
Thanks for any input Chris.
