Curent pics, lets see em y'all!
THIS ONE IS FOR MARK
Ok, ok, ok I know enough already. This one is truly for Mark though.
This is Harold Off's "BOBBED" Scrambler. From Off Again 4X4 in Farmington NM. It has coil over suspension and was in hard core competition up until 2 years ago when Harold build his current crawler....painted the same way BTW. Sorry, this Jeep is just cool.
cj8redleaf, will you post the color code for that orange? I think its great. I'm looking for Scrambler #2 right now (that will be bobbed in some fashion) and was thinking of going Yellow with Black "stuff". I think I may change that now and go orange with black "stuff". That code would be great.
First things first
Ok,the pinon thing-no rotating the pinon up does not make it a high pinon axle-there is appox 3" differant in the pinon height between the regular dana 60 and a high pinon dana 60-rotating only lines the pinon up in a straight line to the back of the transfercase yoke-which you do anytime you run a CV jointed driveshaft-if you still want pics i'll post some this weekend,also the housings and the gears are completely differant between a "high pinoin" and a standard pinion axle,there is also apox $900.00 differance in price-thanks Dan for posting some "trail pics" it's hard to take pics of your own rig on the trail rides,when your the only one with the camera and are usally the tailgunner-we maybe riding Labor Day weekend and i'll see what i can do about some trail pics-I can asure you that this thing is no mall pounder-see Potpouri under summertown tn-We ride hard and use our rigs:D -as far as the trail pics all i have right now are before the paint job and 39.5 rubber-but i will get some new ones as soon as possible and post them-untill then here is one on a trail-JC:D
is it used?
here's another one-JC:p
Dan what is that pink thing in Harolds hands?
Here's the last one untill i get some new ones-JC:D
Nice pics. I can't wait til I get mine going and get down there. Maybe we could arrange a thing next spring down in Tellico and then I could host you guys later in the year in Paragon?
Nice Wheelin Pic Mule!
I can't wait to see the ones from Next Weekend, I know I'll have some good ones!!!
SO, how far do you all have to travel to get into the good trails?
It only takes me about 45 minutes to get to at least 3 "hardcore" trails.
Shi-ute maybe I'm just lucky.
I just put my new drivers seat in tonight (from a 96 Cherokee/replaced my Stock CJ-7 60/40 bench) fixed my CB, installed my Powertank holder.
Man I am so looking forward to next weekend!
Tomorrow I go to Olympia (the place where the beer comes from) to help my old buddy Bart throw his CJ-8 together after 7 long years of being totaled and dormant. Hopefully (unrealistic expectations here ) he can make it for next weekends Nacheese/Manashtash run!
Any Washington State wheelers (must be a wheeler) are welcome.
There is going to be alot of people there and a lot of carnage I'm sure on the Moon and Funny Rocks!
He he he hee I'm giddy.
:D
Mark
How far to wheel
five minutes from the house i have acess to 8000 acres of private land that has everything from stocker trails to trails that will eat 44" tired rigs and spit them out-2 hours to Tellico-1 1/2 hours to Windrock 72,000 acres of trails-3 hours from Blairsville ORV area-4 hours to Summertown 660 acres of wheelin in the country-1700 miles to Siverton Colorado and the San Jaun Mountains-11 Hours to Clayton Oklahoma-not much farther up the road from clayton is Disney Oklahoma-an hour from my sisters-JC:D I can't wait either!
I finally have some pics of my 8 out on the trail. We took it out on its inaugural run after the frame off and fiberglass body swap. I found a few issues I need to correct, but it did very well for itself. I was like :D all day!
Pic 1
Pic 2
SHOWING YOUR REAREND
Ok guys heres the pic of my rear end and how it's set up-It's a standard cut rear-NOT A HIGH PINON AXLE-the spring pads have been cut loose and the whole axle assemble rotatated to line the pinion up to the output shaft on the transfercase to run a CV jointed rear drive shaft-the transmisson and transfercase have been mounted an inch higher than normal,plus the added lenght of the NV4500 makes for a steep angle on the driveshaft and no it's NEVER had the rear driveshaft out of it except to grease it or to change the u joints-JC:D
Here are some pics of where he is at. After T-boning a car at 45 mph and sloding on his side down the highway Bart had to straighten his frame and repair his tub. The Fenders and hood were toast so He is replacing them with original equipment.
Since his axles weren't done and his body mounts weren't there either we did what we could do, basically put on his springs and shackles, finished up his fuel lines, then put the tub on the frame (three guys lifted it easily!) then we lced his tires off to the side so Bart can see how close he is now!! BWAHH HA HA!!! it won't be long now.
Typically I am all for bobbing a CJ-8 (assome of you well know) but Bart really did a great job repairing the tub and had the entire bottom and inside of the tub covered with a Rhino Liner type material (he doesn't know which brand, got the Painting and stuff on trade) and the exterior painted a stock metallic Toyota blue with extra purple under tones in it. This thing is going to look sweet when its done.
As for the Engine He put in a 1979 302/bellhousing from a Mustang coupled directly to a Ford T-18 trans anda Advanced Adapters adapter plate to his Dana 300.
I suspect the B-man will be needing new Tom built axles soon, but for now the Dana 30 front and AMC 20 rear (4:56:1 with Detroit rear, lock rite front) will have to suffice and will do fine for a while I'm sure. At least long enough to get some miles on this bad boy!
6 Years is a long time!
I can't wait to see it go again!
attachment.php
Here it is as it looked when we were done on Saturday.
We set it up like this to get Bart motivated!!!!:D
attachment.php
Me baby
It was hard for me to get the memory small enough. Now if I could figure how to make it 100 x 100 pixels for my avatar! :p
Here you are Joker... just save it to your hard drive and then upload it to the server for your avatar.
Re: Me baby
Very nice looking rig. How did you mate the trans to the D300 and how do you like that setup?
....a Ford T-18 trans and an "Advanced Adapters" (transmission to transfer case) adapter plate to his Dana 300.......
I have the very same adapter www.advanceadapters.com and I love it.
When I installed my T-18 I replaced my T-5 with the Advance Adapters setup in one day. Bolted it all together everything lined up proper. All drive shafts were still in place and at the proper length.
Also the new ones have extra holes drilled out to clock the T-case over allowing the case to be more parallel with the ground increasing clearance under the T-case and tranny.
His is not clocked over nor is mine, but I may clock it this winter.
Hey...
How did you do that?! :p
Looks good Joker...
and its my little secret! ;)
J/K If you have photoshop, you can just go to image size and change the size based on the number of pixels. I also cropped it a bit to somewhat square the picture. I think that came out to be 80 x 100 pixels.
Re: Re: Me baby
I bought this CJ as an unfinished project and limped it home, but the drivetrain was (for lack of a better term) intact. I didn't mate it up, but it was done with an Advance adaptor.
As I said earlier, I only ride in moderate mud, sand and hardpack (you know the area), so the tranny isn't really pushed to the limits. Hell, since I've moved to NJ (from SC), I've only gone out twice!
It's become a slave of the GSP, recently...35 miles to work each way. The first gear is insane (almost 6:1), so I never use it! Ironically, I can only get into fifth if I go 70+ mph. My next step is to go 4.10:1 in the diffs and eventually drop down to 33" tires. Getting somebody to install gears and set lash for less than the price of your first born male child is quite a challenge, though. :eek:
Looks good Joker...
Hey...you owe me 20 pixels! :mad:
BTW, what's a photoshop? :confused:
