Dads Scrambler
Got the radiator hoses in, top one fit perfect. Had to cut the lower one.
More parts came in! Some dash stuff, heater box stuff, air intake parts and arb compressor for the lockers
I need to figure this picture thing out, not sure what I'm doing wrong. I'm using my Iphone 5 to take pics, I know the button is suppose to be to the right when I take the picture. When I try to upload pics from my phone using google it seems like they never download. So I put them on my HP computer and I can only download one at a time and it seems to take forever!
Have you tried the instructions here?
https://www.cj-8.com/forum/showthread.php?47885-How-to-post-pics-from-your-phone-and-other-mobile-tricks-HOW-TO-VIDEO
I used my iPhone 4 with Google Chrome browser without an issue.
Want to hear it run. Your so close i can already hear it in my head. Rumble rumble.
Well I didn't really want to put the computer and fuses in the engine bay. But I had two things working against me, first my harness was not the length I needed it to be. Second, I just didn't have the space for the computer while still using the factory heat and vent boxes.
Starting to get tight on the passenger side...
Got the wiring all done yesterday, it cranks! But it doesn't run :banghead: it tries to though. So after double checking everything I'm pretty sure that I need to clean the injectors. So I'll try that and see what happens.
Whoa that's nice. I also mounted my computer and tac module under the hood to the right and below the brake booster
Ok, a dumb question maybe. In the engine picture is that the fuel pump, filter or a fuel pressure regulator? I say a regulator because it looks like it's hooked up to the return line. I need to install a regulator on my 5.3.
Thanks Guys! So I pulled the injectors yesterday to clean them up and they where filthy. When I started testing them only one would activate :huh: So after a few phone calls to parts stores we where in business! :cheers:
Not sure which picture you are talking about, but I'm guessing on that shows the drivers side of the engine. I have a pressure gauge inline on the supply side so that I can make sure I'm getting the correct pressure to the rail in case I start having problems.
Sweet. Glad to see it up and running
