Dads Scrambler
Time to step up my game i think your winning. [emoji12]
Got the rocker mounted up, drilled some holes in the tub [emoji51]. That was nerve wrecking. And then used the hoist in my ceiling to get the body back off so I can fab up a crossmember and run some brake/ fuel lines.
Good progress. Looks great. Are those the poison spider rockers? I am looking to get some or reuse my old ones somehow. Do you think they would work with my glass tub? They still use the body mount locations too, right?
There from a forum member here Dain he makes them from time to time. Yes I have them tied into the body mounts
It's a Bryant family affair! Man I miss the Jeepin' crowd! Oh, and happy birthday BTW. Cheers, Dylan
Thanks guys!
Parts are slowly trickling in.
Hopefully I can get the rockers, nos door and front cage to paint this coming week. Then that will really free me up to do some stuff
Thanks guys!
Those didn't take long to come in...
It's nice coming home in the morning after a 24 hour shift to find jeep parts waiting for you [emoji41]
Welded tabs on the skid plates to catch the front body mounts. Used plasma cutter to cut out holes for the body bolts and front drain holes in the floor pans. Drilled the holes to tie in the front cage mounts.
Welded in the Novak motor mounts.
I was going to start the crossmember but I got the wrong adapter mount from advance adapters.
Does the skid plate extend far enough in that it interferes with the parking brake cable?
Do you mean the underneath of the rockers? You know I did look at that, I may have to make another notch.:crazy:
Paint!
We used a textured bed liner that is colored. We are going with the original color of the tub. Slate blue metallic
So that's primer and then you shot it with slate blue Bedliner? That's awesome!! What company did the liner come from?
Sent from my SM-N930V
I think it's a 3M product. Tintable bed liner, meaning you mix your paint color in with the product.
Sunshine, is there an upgrade knock sensor harness? I know there have been issues when trying to replace the knock sensors. Honestly I don't think my wiring harness is going to use them, I need to look at it again
