The yokes are not the problem, I can't get the damn thing high enough. Try to imagine (i'll take a pic tomorrow) a quasi box created by the transmission in the front and exhaust pipe on three sides. The Tcase input and the rear driveshaft yoke are inside the box with the front driveshaft yoke and the shifter linkage hanging down.
Ok move the input and rear shaft over to the left and then lift the front yoke/linkage up through the right side of the box . The Tcase hits the floor before it gets over the pipe. the problem is that it needs to move left to go higher, but it cant go higher without going left. It ain't happening, it was super difficult to get it out I almost gave up. Now without gravity, no way, besides, if I can tweak the exhaust a little so that next time (and there will be a next time) I wont have to deal with this **** then it is worth it. I was at it for HOURS! I would have to take breaks and think about for no other reason than my arms would get exhausted from lifting and moving it around. I'm going to have an exhast guy look at it and if he thinks he can move things a bit to create more room It will be worth it for next time.
