dana 30 questions
cjrusty
belleville
il
i have a few questions about my dana 30
i am running 35's and 4:88's and open diff
i am sure axle breakage is in my future
was gonna start looking for used shafts to keep with me just incase.
but i have never worked on a axle, I guess what i wanna know is could i fix this on the trail, hard or easy?
Do my spare shafts need to have bearings already press on.
what kinda problems could I encounter
any help would be great.
any special tools I should have
should i bother with getting new stronger shfts or will I end up breaking new expensive shafts
I figure your correct...just a matter of time depending on how extreme you get.
Replacing an axle gets easier and quicker with experience! You hope you don't get much experience!
Before you even go to the woods, I would take one out and put it back in again. You'll find out what tools you need too! Good Luck!
Unfortunately, axle breakage isn't the only issue with the Dana 30 and 35's. Replacing a ring and pinion isn't really a trail repair.
Mopedal (and a couple of others) helped me pull my d30 shaft at the 2007 Nationals when I had a weird noise coming from the front end (turned out to be a stuck caliper). Once you do it, you realize it is not really very hard, but a little practice removing it can't hurt.
I had a narrow-track and wide track d30 sitting around here for spare parts, so after my experience at the Nationals, I ended up disassembling both axles to pull the shafts (short outer shaft is same size for both NT and WT), extra bearings, and spare hubs. So now I have plenty of spare parts for the trails. I would recommend you find a spare d30 and get yourself some spare parts from that. I still need to put new ujoints on my spares. My plan is that in case of breakage of an axle or ujoint, it would be relatively easy to remove both the old axle shafts and slip in a new one.
Not a hard job. The bearings are not pressed onto the shafts. Depending on how much rust there is, it's a little hard to get the spindle (part #16 in the linked diagram, below) off. You can beat on it with a rubber hammer (or gently with a regular hammer) or you may need to use a flat head screwdriver or pry bar to work it off.
There may be a little variation on the spindle nuts holding in the bearings and the shafts, but you should go ahead and get the right size spindle nut socket before you get stuck in the woods. I can't remember the size off the top of my head but the standard one is listed on the diagram, also. You need some snap ring pliers, also, if I remember that correctly.
Here's the diagram:
http://www.tellico4x4.com/images/products/omix/d30.pdf
That's all I can think of for now. Hope this helps.
-Mike
thanks, I will look for a whole axle and dissassemble it, and back in to get the practice.
now what if you break the shaft just inside the axle tube. how would you get it out?
Heavy fishing line tied in a lasso loop is how I've done it before.
Truck
