Dana 300 parking brake?
jeepdreamer
Colorado Springs
CO
Hey guys,
Does anyone have any good intel on a kit for putting a disc brake behind the dana 300? I know the early Jeeps and landcruisers used a drum set up that was leak prone and there are folks making aftermarket "kits'' to do this but I can't get any info. I've sent emails with questions to JB conversions and All Pro but they didn't bother to write back...big surprise. But I need to do something and the factory one just isn't cutting it. I don't want to replace it with new stuff only to have another marginal e-brake when I can upgrade... Anyone have any ideas or help here??
vehicle..
83 CJ8 Scrambler. Soon to be NV4500/Northwest fabworks Blackbox/Dana 300...
Why...?
Why? Well, in a nutshell the factory CJ e-brake is only moderate in stock form when functioning perfectly. Add to that the mods my jeep has gone through and the age of the worn parts and something must be done. I've adjusted it many, Many times and still can't make it hold well enough to make me happy (or confident). And since the military makes you have it "tested" before it is allowed to be put on a ship for a move...I want to upgrade.
A t-case mounted one is a far superior for mechanical advantage and ease of use IMHO. I just need to find out where to get the stuff...
You might not have recieved any replies on it, because its illegal. If any part of the driveline falils the brake doesn't work. Drive shaft breaks, u-joint fails, diff gears, axle, hub fail the brake is useless.
You might search Pirate 4x4. They do a lot of unusual stuff there.
Would the military accept it, even though its not legal?
so why do buses have it? old toyota land cruisers have it too... there are ALOT of vehicles that have it. (older vehicles.)
You've answered your own question=older vehicles.
I believe all commercial vehicles like buses have air brakes. Which lock when the vehicle shuts off, because of loss of air pressure. So they may have a brake on the drive shaft as a temporary parking brake so they can leave the thing run while they go pee. I'm just guessing at that, but I suppose you could google the real answer.
I just worried you put a bunch of effort into a drive shaft brake and the military says they won't accept it.
Maybe we can figure out how to get your existing e-brake to work better.
What's the test it has to pass?
correct me if i'm wrong... but isnt an 83 Scrambler an "older" vehicle??
interesting responses...
Hmm...not the responses I would have thought would have come up but thats good. Let me start here...
The "Army Test" is really a civilian inspection we have to go through in order to have our vehicles shipped. They check for all sorts of things from cleanliness to mechanical functionality. Some things are more to protect the transporter from liability while the vehicle is in their hands. But much is aimed at ensuring no unsafe, illegeal, or dangerous vehicles will be shipped. The part of the test I had the greatest issue with was the parking brake test. For the average, normal car it probablly isn't even a thought. But for mine it posed a bigger deal than you would think.
For the test they have me back my Jeep (V8, 5speed, 4.10s on 35s) onto a 40% incline, set the brake and put the vehicle in gear. The brake is required to hold, even under load, at that incline. I'm sure they do it as a "saftey issue" for the workers that put the vehicles on the ships but seriously? If someone got out of a manual tranny vehicle with it running in gear they probablly shouldn't be working there.
But the reality is that the stock (all rebuilt and working fine) brakes don't have the mechanical advantage required to stall out the jeep given the gearing and the incline. It just sees it as another rock to be climbed.
Would rear dics and intergrated parking brakes improve that?Sure, I would think. But the other thing is I really don't want to put any more effort or money into that CJ AMC20. ven with the FullFloat kit I just don't see it lasting forever. But for now it will suffice.
The other thing is I will be pulling the tranny/Tcase soon anyway and that would be a good time to do what can be done. I will need new driveshafts anyway and this seems a good way to fix the parking break issue.
The Older Jeeps and LandCruisers used a drum style parking brake, not a disc. They were notorious about loosing the seal and allowing gear oil to escape the tcase and coat the parking brake shoes, thus making it useless. Add in mud or water crossings and you see the same basic advantages we all do with drums over discs.
The breaks on most Busses, large trucks and military vehicles are air operated. There is generally no mechanical parking brake per se. The vehicle must reach a certian air pressure (usually about 100psi) before the brake system will function. But it works sort of in reverse. The design normally is applying pressure to the axles via a spring. When air is introduced it pushes that spring and allows the brakes to disengage and movement can happen. Low air pressure, blockage in an air line, or even frozen condinsation can sometimes cause the brakes to NOT release. A truck (or trailer, works the same) will either not be able to move or it may simply drag that stuck tire. But either way that is not really an equal comparison.
My buddies 78 FJ40 has this style e-brake and a school bus transmission I had also had this setup. The brake does not go to the drive shaft. The brake actually is for the rear output shaft. The backing plate attaches to the housing and the drum is secured to the rear output shaft flange. Both the examples I have seen use an output shaft that has a flat plate attached, i.e. the drive shaft bolts to this plate, not the more typical CJ style where the U-joint connects the drive shaft to the rear output yoke directly.
To do this, you would need a different rear output shaft and a bracket to hold the caliper, I would think.
From a safety stand point, this style of e-brake would work fine, unless you break your rear output shaft. Once the shaft brakes, no more parking brake, but if you did brake the rear output shaft you would still have wheel brakes, so i don't see the concern.
I have disc brakes on the back of my Scrambler, but I still need to hook up the parking brake, so i don't know how well it works. The style I have will physically compress the caliper, so I would think it would work well.
Let us know what you find out:thumbsup:
why put old technology on it? Jim's Chop Shop nailed :twocents:
Rear discs with a solid ebrake would be sufficient.
yes youre right... the drum brake on the tcase is old tech... I wouldnt run one of those. My point is that vehicles have ebrakes from the factory on the tcase. I wouldnt run a drum brake on the tcase. Old tech, for sure.
I WOULD run a disk brake on the output. I actually have all the parts to do it to my Jeep. Just havent gotten around to installing it.
The problem with ebrakes on the axle, mainly for lifted Jeeps, is the cables are a pain in the ***.
Out put up grade...
The kit i found is used I'n conjunction wit the Advance Adapters 31spline out put shaft upgrade. It uses the bolts for the output flange to secure the caliper bracket and runs the round/flat style yolk instead of a normal Jeep U-style one. And as mentioned, a failed rear shaft shouldn't have any bearing on it's operation, especially if the front axle is engaged. At some far future point the rear axle will be swapped and i can address an axle mounted version but for now...
A little update...
I've been doing a little surfing and found a few things related to my original wishes for a T-case mounted Pbrake. Since the 8 is wounded (bad tranny or t-case) and I don't have time right now to order and recieve the parts before I head to Afganistan, this is all just bench racing until I get home.
The first thing that needs to happen is an upgraded output shaft for my dana 300. I was planning on giving it a refresh anyways but with something having gone bang...this may be a full rebuild. May as well upgrade to heavy duty stuff while I'm at it.
From searching there seem to be 2 people to choose from for a HD rear output. Advance adapters and JB conversions. I'm leaning more towards the JB kit as I like the way they design and build stuff. Not that there is anything wrong with AAs... its just a preference.
As to the parking break mounted to the t-case there seems to be about 3 "kits" from people and probably a few ways to DIY... I'll just stick with a kit since I have to order what will work and have it sent here to Germany. :( It looks like AllPro, High Angle Driveline, and PartsMike all have some sort of prepackaged kit to work from. I'll likely go with the PM since I've delt with them before. It will be a while before any of this starts to see the light of day but I still welcome any thoughts and opinions. Better now before the money starts to flow... ;)
Another way to go on this would be a hydraulic line lock. You could lock just the rears, or all four wheels. These were a requirement back when I used to do tractor/truck pulls.....
