Decal Kits
timo439
Portsmouth
NH
The scrambler is in the middle of a pseudo restoration and I need to order a decal kit. There are several threads on different kits, but I cannot get a sense of which maker provides the best quality kit while remaining close to factory specs. I have been given both Pheonix graphics and Austin Jeeps as recommendations. Does anyone have an opinion of who makes the best and most complete kits?
I am not doing the work myself but will post pics when it is done. It is currently at Toybox jeeps.
Thanks all. happy New Year.
Decals
Have you talked to Pete? He is one of, if not the best restorers of Scramblers in the country. He can most likely save you some money on the kits and has experiance installing them.
Look forward to seeing some photos. How far along is the restoration?
:wave:
By the way, Welcome
Thanks for the feedback. I have spoken to Pete quite a bit and he did recommend Austin Jeeps. I'll probably go with them but was curious as to others experiences. I a, glad to hear you hold his work in such high regard. I have been impressed so far.
The 8 is Just being torn down now. Its getting everything done but an engine rebuild as I've already blown the budget. I know it would make sense to do it now though...
I used Golden Eagles decals. They are the only company that lists what they use for the kits....3M Scotchcal. My installer said to get the 3M scotchcal and i did. Golden was also the cheapest. They look great and went on easy. Just like original.
Karl
I installed the Austin Jeeps/Golden Eagle Decals decal kit on my current project- a 1978 Golden Eagle. The kit was pretty easy to install- however I would recommend a warm day. I tried to install mine in 48 degrees- the cold made it much more complicated. I have used their kits probably 10 times- no issues- but take your time.
Full disclosure- I consider Mike at Austin Jeeps a good friend- so I may be biased.
Thanks
Kyle
I have been in the process of helping Phoenix Graphixs reproduce Jeep Honcho decals and although I haven't personally used any of their kits yet I can assure you they are very particular about being very accurate to the originals. I have heard good things about them and I will be using one of their kits for my Scrambler build.
My :twocents:
I did a bunch of research on the subject a while back when looking for my kit. From what I learned (which may be complete BS but I don't think so) there is only one manufacturer of decal kits that is "licensed" by Chrysler to make them. They have the original colors and dimensions. I don't think you can buy direct from them, but Collin's Brothers is one or their distributors. This is where I eventually purchased my kit. It was very nicely done on pretty good vinyl. The hood stripe was creased (maybe from shipping) and they sent me a new one pretty quickly without much hassle. If you need the name of the company PM me as I have it as part of the return process. ;)
Vinyl is pretty easy to install, especially if it is pretty warm but not hot. Direct light is a bad thing as your sheet metal will get really hot making the install much harder. A 60-85 degree day out of direct sunlight makes it pretty easy to lay it down and pull it back up if it isn't exactly where it should be.
Phoenix Graphics is an officially licensed Chrysler/Jeep reproduction parts supplier. My decals came from them, went on perfect, and are holding up well:twocents:
Since 2 have mentioned it, Phoenix Graphics is where mine came from as well.
