Do you want to do an engine swap...
I wonder if that would fit in my 47 2a ?
Thanks for sharing the link! You could build that much power for much cheaper than that one....not sure why anyone would want that much HP in a CJ though. I can attest that 420 hp is scary. I can't imagine > 700 hp
This is the article:
CLEVELAND POWER & PERFORMANCE IS PROUD TO OFFER THIS 2015 DODGE CHARGER HELLCAT 6.2L SUPERCHARGED HEMI ENGINE AND ZF 8HP90 8 SPEED AUTOMATIC TRANSMISSION DROPOUT WITH ONLY 13K MILES
WE SHIP INTERNATIONAL AND DOMESTIC! PLEASE CONTACT US FOR A SHIPPING QUOTE!
THESE 6.2L SUPERCHARGED HEMI ENGINES MAKE 707HP AND 650 LT-LBS OF TORQUE. THIS RAW POWER IS PRODUCED BY WAY OF THE FACTORY 2.4L TWIN SCREW SUPERCHARGER RUNNING ON 11.6 LBS OF BOOST.
THIS AUCTION WILL INCLUDE THE FOLLOWING:
BELT DRIVEN ENGINE ACCESSORIES
ENGINE HARNESS
ENGINE COMPUTER
BOTH UNDER HOOD AND TRUNK MOUNTED FUSE BOX’S
BODY CONTROL MODULE
ANTI-LOCK BRAKE UNIT
COMPLETE PEDAL ASSEMBLY
SHIFTER
STEERING COLUMN
STEERING WHEEL WITH SPEEDOMETER AND RADIO CONTROLS
IGNITION WITH PUSH BUTTON START
BOTH RED AND BLACK KEY FOBS
BODY HARNESS WITH DASH & UNDERHOOD HARNESS’
HELLCAT SPEEDOMETER W/ FUNCTIONAL PERFORMANCE INFO
TOUCH SCREEN NAV RADIO WITH CONTROLS
HELLCAT FUEL TANK WITH FUEL PUMPS
CATALYTIC CONVERTERS
INTERCOOLER W/ TRANS COOLER AND RADIATOR
INTERCOOLER PUMP
RADIATOR AND INTERCOOLER OVERFLOW BOTTLES
REMOTE OIL COOLER
ENGINE COOLING FANS
HERE IS THE VIN FROM THIS CHARGER – 2C3CDXL94FH773289
At Cleveland Power & Performance, each motor and transmission are inspected and run tested before we back them with our exclusive 6-month warranty! Before we start each engine, we remove the spark plugs and hand turn the engine over to make sure that no oil has passed the rings. We do a compression test to make sure the piston rings, intake valves, exhaust valves, and head gaskets are properly sealed. We do a vacuum test to make sure there are no burned or sticking intake and exhaust valves, collapsed lifters, or vacuum leaks. We do an oil pressure test at cold start up and warm operating temperature to ensure proper rod bearing clearance and that there are no restrictions in the oiling system. We do a CO test to make sure there are no cracks in the engine block and cylinder heads, and that there are no exhaust gases in the cooling system. We inspect the auto transmission by draining and inspecting the transmission fluid. We check for any debris or foreign material. If any problems are found, the transmission will be torn down for inspection and repaired as necessary.
Compression was 210 on all 8 cylinders!
Oil pressure was 60 pounds cold and 50 pounds warm
Vacuum was a SOLID 15”
CO check PASS
Wow...that's quite the test stand. Out of wood....
What is that engine good for at that price?
A restomod 60's charger or cuda?
If you are really looking for 700-1000 HP for a drop in race car you can do better for less (I think). What do you think sunshine?
