Ebay find
mysunnshine
Phoenix
AZ
I'm sure I'm not the only one that saw this one. It's kinda hidden away and mislisted....
http://cgi.ebay.com/ebaymotors/1973...oryZ6280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I realize that anything is possible...
but this auction says:
"Up for auction is a 1973 Jeep Commando. The jeep has a Scrambler fiberglass body on it."
Are early Commando's & Scramblers easy to interchange??
C/C
The wheelbase is the same 104" on a '73 Commando, not sure about actual frame layout in terms of body mounts. Overall length on the frame is probably different. Looks like the body mounts have been fabbed. Interesting.....
Paul
Owning both a Scrambler and a Jeepster Commando, I can tell you that a Commando frame from 72/73 will work with modification of body mounts. It's not an ideal setup, the Commando frame stays one width from the front to the back, and the rear spring hangers are outboarded. The frame is not as strong in stock form, but that can be fixed with boxing. The biggest drawback is the spring length. They are longer on the rear half than a Scrambler. Custom springs have to be built for a lift. But, the frame can be modified to use standard CJ springs. and if you move the rear springs inboard to mount under the frame rails, you can get some pretty good flex. Commando frames are fairly easy to come by, and cheap to buy. I usually can find one or two for a hundred bucks or so.
I guess if your Scrambler frame was way beyond repair, a Commando frame would be a cheap way to go.
