Hi everyone; I am new to all this so please bear with me... I am trying to figure out the estimated value of my Scrambler that I recently aquired and wondering if you people would help me.
The Jeep that I got is a 1985 CJ-8 Scrambler- here is all the info about it:
It has a Mopar multiport fuel injection, K&N air filter. It has a rebuilt engine and transmission (5 speed), transfer case (three speed transfer case conversion), and differentials. It also has a total of 10 near new goodrich 30x950 AT tires (4 on it now and 6 spares).
It has new ARB air lockers front and rear. New Warn lockouts on the front and near new Warn full floater axels (I recently had to remove the lockouts in the back and replace them with Warn Drive flauges?). It also has a Warn 8000 winch, and a oversize fuel tank.
It has near new Rancho springs and shocks, 21/2" lift soft ride, and quick release sway bar.
It carries a light bar with flood and straight beam lights. It has new mopar hard doors, also has a extra set of old hard doors and soft half doors. The interior is all in great shaped- seats and everything. It has a full factory top, an older full soft top, bikini top and a tonneau cover. Original bulkhead is still with it.
Extra stuff that it has: tow bar, chains, fiberglass windshield frame, nurf bars and aluminum coverups on tubs, poly obdy mounts, steering polly bushings, tonkin steering box strut stabilizer, and stainless steel brake lines.
As for the exterior condition, there is slight rust by the driver and passanger side doors. Otherwise rust free. Not dents or beatings (the paint job is pretty bad but can be fixed easily). The total miles on this scrambler is about 15,600.
I realize that I wrote a bunch of stuff here, but I wanted to provide as much info for you guys as possible to get a good value estimate. I am working on getting some pictures for it when the weather gets warmer. Based on what I wrote what would you say the value of this Scrambler is? Or should I say: if you didn't own a Scrambler or wanted to get one and you had the money- how much would you pay for it?
a. <$5000
b. $5000-$7000
c. $7000-$8000
d. $8000- $10,000
e. >$10,000
Thanks for your help guys!
a. <$5000
b. $5000-$7000
c. $7000-$8000
d. $8000- $10,000
e. >$10,000
