FINALLY!!! Passed inspection=LEGAL
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
WOOOOOOHOOOOOOO!!!
It's over... I still have some sort of noise at higher speeds, but I got the postal to the inspection and it actually PASSED! I can't really believe it, but as you can see from the form, it passed the hell out of that emissions test.
It was quite amusing when the older fella that was going to do the inspection got halfway into the Jeep (quite a big step for him) before realizing that he was on the "wrong dad bloom side". :D :D
What topped it off was the Jeep wave I got from guy driving a TJ on the way home :D
Damn, looks like the page is basically unreadable when it got shrunk down...
the important numbers for the emissions test are in the box on the right:
Emissions Test Results
PASS
HC (ppm) Reading: 96 Standard: 220
CO (%) Reading: 0.00 Standard 1.2
CO2 (%) Reading 10.8
Hot diggity!
Congratulations
I now realize how you passed, you had to get a left handed inspector to do the test.:D :D :D :D :D :D David "Papa Bear" Mc Ilrath:D
$70.00
That cost $70.00? Are Postal 8's emission exempt,like the postal DJ-5's are?The postal DJ-5's have a big emission exempt sticker on the dash board.
It was $30, funny because the "range" of prices they can charge is $6.50 to $30 but for some reason they all charge $30.
I need to get the valve/rocker/pushrod issue sorted out and then I can think about the daily driver :D
Texasscrambler said:
Thank god for Texas. About 12 bucks, they honk the horn and check the lights and slap a sticker on it.
Unless you live in the Dallas/Ft Worth area. $40, smog test on a dyno and if you've installed anything with OBD2 you get hooked up to the scanner too. Fortunately my LT1 has OBD1, I'm getting it inspected tomorrow at the same place that's building my exhaust... ;)
Thank God for Texas
I think Texasscrambler was talking about the part of Texas WEST of I-35. You folks that want to live in the Metroplex or Austin/San Antonio or worse yet, Houston, are just gluttons for punishment. :D
You know it is really funny that after many years and miles (175,000) on my old 81 scrambler I haven't given it a full tune up in 3 years. ( kids and work so I get by with what I can on a tight budget) I haven't been putting a lot of miles on it so I wasn't all that worried about it. I just figured the emissions would be a little worse each year until I did the complete tune up again. After 3 years it has gotten better and not worse?? I know there isn't a bunch of holes in the exhaust since I replaced that last summer from tail pipe to manifold. So Big Walt don't stress if your old jeep just gets better with age? in Colorado on the front range we have to do a standard tail pipe test. $15.00. Soon I can put collectors license plate on the CJ-8 when it turns 25 years old and then I only have to do the emissions test once ever 5 years.
On another note I have a buddy who has a wrangler and he has to have just enough gas to get to the emissions testing station and then he adds a bottle of "Heat" or de-icer into the gas tank and his passes everytime. If he dosen't do this it will fail everytime? Just a tip if you are just squeking by. Also try a new air filter. That can make a huge diference in the readings coming from the computer.
Tom, it wasn't that I couldn't pass... it was just that I got the Jeep last July and hadn't gotten plates and inspections done until just recently. i couldn't really drive it since I wasn't legal.
I had no idea if it would pass the inspection or not, but I had to try within 10 days of registering it and getting the new plate. I was just thrilled to have it done.
You're right though, I have heard that the bottles of different guaranteed-to-pass type products work great. I've also heard that since they're basically just alcohol anyhow, you can pour a bottle of some type of alcohol (rubbing?) straight from the drug store in the tank to get the same effect. Do your homework before trying that though. :D
