firefighter736's Build Thread
Spent the day on the bed liner. Hope you guys have your sunglasses ready :smokin:
O yea [emoji106] [emoji106] [emoji106] [emoji106]
Sent from my SM-N910P
I don't know why but the first thing I thought of was a Margarita and I'm not a big drinker.
Hey guys,
It's been dink and dunk lately as we worked to finish up my friend's new garage. We finished it up by pouring the concrete pad Saturday... now it's time to move in the Jeep and finish this thing up!
RvMltzs4-RMIDLYvvNjv7Gjd8OADQOjoMOk_rCctcEGwQujc7k_dpF_ZP-rhEuLi6bv4ol1jQlmBiIlZMMKDBoAN4yq1_-k-yPcVTbd11RjvIpD8jpv-_B9wbcwn50X06zEeOidM4WcXL68qUankWZkaHIVXmKHyokEU48YWY-ezKACfE74LyLrgYKeDLcIdpBNiVDZUKToB60WL3UTlZSqDzdO0DbNG_4oTIJy5YQhaW3T4opA_9tUf6e1ZJpzB1Urtd6lj-kaBocjaWoYYEdLrUXQ2pM7QrwWfjPlPeKBoRtAXEZQdqM6qrXmdvKVU4OjB4uo2GAeY3PWNN601gwIDvaX-vOmuI_8dWUnYupAmfYtzSibKceuOzvthvBhAjE0C3AoJHp2XzDGZ3cLdKuIR41I996OYjsVcA-VyYk3jlBr7-49wpLoMxBxrAovV1jov2BRq79jpMqhb_9FX7G7TqpV5K5q2n1Rn0WrOnBMNUS9v8eySqV0AH8dbvHlgKKPy2lZBDL1tEeUxFx2bXmIJEXD-jPR1oseGtPFlp40mXAFYLy37LzfG-04ncik2hvjpyWHDXBF5wvOEGr5BdXiVNyTtYMAA=w1183-h887-no
While helping him on the garage on the weekend I worked to get my drivetrain finished up. The 5.0 is buttoned up
I sourced a T177 from our good friend Dustin (JeeperDD). Got it painted and mated to a late 70s F150 bellhousing
I worked on my D300, too.
I pulled the inspection plate off to check everything and it appears that while in storage quite a bit of water got in the transfer case.
I cleaned out the gunk, installed new seals, and gave it a nice coat of paint.
This week the entire Jeep should be at my friend's shop. First step is to get the drivetrain set. Second is to run my NiCopp Brake and Fuel Lines. I'll then set the tub on and start really hammering on getting everything back together.
If feels so close, yet so far away.
Also, for reference I put together a parts list of stuff to do a 302 (5.0) conversion to a T177/D300. Maybe this will help someone else who is googling.
NATIONAL FB1625C Throwout Bearing
M-PACT 261009 Pressure Plate
M-PACT 383348 Clutch Disc (General Motors 11" x 10 tooth Disc)
Dorman 690-023 Pilot Bearing
M.O.R.E JM500 Motor Mounts
LuK LFW161 Flywheel (164 Tooth, 50oz imbalance - make sure you match your imbalances between your flywheel and your damper).
Ford Truck Bellhousing + Blocking Plate (I’m using one from the 70s = steel, but people prefer from the 80s = aluminum + hydraulic clutch)
A lot of work done Friday night and Saturday. Got the motor and transmission mounted and the skid plate lined up and drilled.
Set the tub on the frame to make sure the engine cleared the firewall.
I started bending brake lines. NiCopp + Mastercool hydraulic tool = nice flares
Interesting - can you guys see any pictures from the last month or so?
Post 126 had this:
And then two normal pics.
Pics have been on and off since then, but thought it was interesting that 126 had one with an issue and 2 normal.
Last one I see is from 6/21 as well.
Wait. Edits being made. I now see a rolling chassis on 6/26. ;)
