Flat towing my CJ8 does not track properly
cjgoode
Central
FL
I have flat towed my cj8 a lot with no problems at all. Last summer we drove it at the beach all summer, and when it came time to tow it home it does not always follow the tow vehicle around turns, or it does not straighten out when coming out of the turn. No modifications were made to the vehicle in between when it towed fine and when it decided not to. We tried to tow it again yesterday and same thing, every one in a while it does not follow the vehicle into the turn, or does not follow out of the turn (It keeps turning)
The tow bar is about 4 or 5 feet long and level when towing.
The jeep has a shackle and spring lift on 35's use to tow great with this exact combination. I ordered a drop pitman arm and new tie rod and drag link this morning since I needed them anyway. It drives perfect down the road, no swaying at all, it is great on the road, just not so happy towing it.
Power steering box is fairly new.
Any ideas why it would not tow properly, anything else I should look at.
Maybe try hitting all the lube points with grease, sounds like something on the front end is hanging up
You could try to pop the drag link off the knuckle to see how it does with just the tie rod connected, see if that narrows it down for you.
Good idea on lubing all the various spots.
you said you have made some mods to your jeep,what did you change since it last towed correctly
"No modifications were made to the vehicle in between when it towed fine and when it decided not to."
No mods since it towed fine.
sorry I guess no was hidin behind my little pointer thing:eek:
How is your alignment? I'm too tired to think of which parameter you should be concerned with, but if it is out it can resist turning back to center w/o help.
Sounds like an alignment issue to me too. Especially seeing that towed fine before.
Could be a more worn part has caused a borderline issue to become more of a problem.
Usually it is caster that is the biggest culprit, but toe can also affect how it goes down the road.
Carl
Thanks to all, this should give me some good info to look into when I go back over to where the scrambler is this weekend. I think it just likes the beach and does not want to leave.
I will be putting in a drop pitman arm and new heavy duty tie rod and drag link. Will see if I can get some shims as the caster likely needs to be adjusted with the longer shackles. Maybe when it was towed over there it was on the edge anyway.
Will let you know of any progress next week.
Was the Jeep weighted any differently - did you have lot of gear in the back one of the two times?
the longer shackles will throw the caster off,i put them on mine and now i think that was a big mistake,front end shop put 2.5 degree shims in it and i now only have 0 degree caster and it will not return to center without help.
But my jeep drives great, nice and straight, I can cruise down the road with 2 fingers. I would bet the caster is the problem with towing, but not a problem driving it, or could be the angle of the drag link. Tie rod ends could be bad, but those will be replaced this weekend. If I had not towed it a lot before, changed something, or if it did not drive so nice I would not be so puzzled with the problem. Most of the time it will return to center when towing it, once in a while it will not, but same for going to a turn, mostly it will follow you but once it a while it will not. Definitely not worth towing it for safety reasons.
If I jack up the front end I can grab either wheel and turn it from left to write with no binding at all.
Very odd. Monday I will have all the new parts in and everything greased up.
We went to take it home at the end of last summer and it started having the problem, every once in a while I hook it up and try and tow it around the area to see if it still has an issue in case you are wondering, I usually have to get out and straighten the wheel or disconnect it and drive it back to the house.
Got new heavy duty tie rod and drag link, pounded the old ones out to only find out my 84 has had an axle swap and now has narrow track axles. So I have to ship back the links and get the ones for narrow track shipped. so it will sit for a while now and not be drivable either. Once I get the correct links in will try and tow again after checking a lot of the above info.
while you have every thing apart have you thought about doing a tie rod filp on it?
