Found a 401
CrazySchaefer
Registered Crazy
Liberty
MO
OK so I found 401. Fo sur 401! now the bad. Its been sitting in the bed of a pickup, for man says 7-8 years. Pulled out of a running cherokee for a cj-7 that had blown motor bla bla bla......anyway I am looking at it best I can and here is the problems I see.
1. Was covered at one time with a tarp that is some what left. Its very tattered and flimsy to the point it just kinda pulls apart.
2. at some point a guy that was going to buy it put the bottom half of an air cleaner upside-down over the carb-but now it direct water from a six inch circle directly into the carb! I had a walmart sack I went ahead and covered the carb with.
3. There are no exhaust manifolds on the motor at all.
4. Flywheel was for auto-I need Manual flywheel.
Now the good
1. Free!!:eek:
2. Does look like at some time before 7-8 years ago it was rebuilt.
3. Complete other than the exhaust manifolds even has AC bracket and pump.
4. It looks better than what I thought it would-no parts or gapping holes in the block.
So what do you guys think? What kind of condition is the inside going to look like? How much is it going to cost to possible get it running? Oh and did I say it was FREE!!:D
Grab it! And plan on putting a couple of grand into it if you have the talent to rebuild it yourself. More if you'll need to rely on an engine builder. It likely will require a complete rebuild if it has been outside for that long, but it should be salvagable!
Scott
If it is free take it. Plan on a rebuild... Exhaust manifolds can be difficult to locate sometimes, but I believe I have an extra set in the garage...
The only problem I could forsee is the previous rebuild. If they machined it when it was rebuilt, I am not sure if it can be rebuilt again... I know on some engines, you can get 1 possibly 2 rebuilds before the walls get too thin... I am not an expert, so if someone here is, please inform!!!
My experience is you can go at least .040" overbore w/o any issues. Check out www.bulltear.com Matt (jeeps4ever) is a great resource.
Scott
Thanks Im kinda excited kinda dissapointed I didnt follow this lead years ago when I first heard about it. Hind site is 20/20!
Just get it and then figure it out from there...
We need pictures!!! :D
Well sorry it took so long.well I think its shot. havent pulled the oil pan off so I dont know about the crank. There was water in 3 cylinders.RUST was EVERYWHERE!! I will try to get some more pics up later...
If the block is trash (I can't say for sure from the pictures); the crank and rods (if they are good) are forged. That's better than what comes in a 360, cast stuff. You can use the 401 crank and rods in a 360 to build a stroker motor. Something around a 383. It's similar to using 400 SB Chevy crank and rods in a Chevy 350. It makes an awsome motor.
Just put it back together, pour in a little Marvels Mystery Oil...that should work:D
