Frame-Off : Harness
leeherron
Pensacola
FL
Frame-off on my '81 CJ-8
So I'm thinking of building my own wiring harness. I've looked at the Painless, and a few others and question as to if I shouldn't just build my own.
Now I own a store that specializes in 12v electrical .. (audio shop) and already keep 30+ color / sizes of cables on hand. Am comfortable working with wiring, and can read schematics.
Any suggestions on best schematics to use .. links to them, etc.
Any warnings that I might should take in to consideration?
Any thoughts?
Thanks
lh
Dude, slow down over there, you're making the rest of us look bad. A week in and you already have the tub off and you're planning your wiring install. You know how long my Painless kit has sat on my bookshelf? A year and a half now.
A few years back I built a replacement harness for my 42 Ford Convirtable. I simply removed the old harness and laid it out a a sheet of plywood.
Using the old harness as a pattern, I started at the taillights and worked forward. Then went to the headlights and parklights and worked back. Then did everything under the hood and dash.
At the time I couldn't afford an after market harness. Took a bit of time. once everything was done and working. I had 1/4 what a new harness would have cost plus a lot of time invested.
Would I do it again. Since a Scrambler is so much more complex, probley not.
You're in the perfect position to make your own, including upgrading (especially some of the ground wires). You've got the wire, probably have most of the proper connectors, so really the only thing to come up with is what you want to add on and incorporate that into the harness while it's going together.
I have built 5 harnesses and used 3 Painless and another that I don't remember the name. I would definetly use the Painless harness if and when I do it again. You may have all the wire in stock and most of the connectors but you still need to figure the cost of those because you have paid for them. Also, things like the fuse panel can be difficult to find or integrate into the harness due to the availability or condition of your existing. One thing that I really like about Painless is the wire identification every 6 to 12 inches and that the colors are the same as in the factory schematics. This makes later troubleshooting much easier. The last item that I really like about the Painless is time. I enjoy working on my project Jeeps but I much prefer to use them and anything I can do to minimize work or troubleshooting time is well worth it.
GOOD LUCK with your project: flag:
I might consider it, but only if you make detailed drawings to go with it, or are you saying you'll duplicate the wiring colors from the stock harness?
I agree with the point about the fuse block, I'd say you should look to see if you can find something you want to use for the stock replacement block first and go from there.
yeah...what he said. :rotfl:
Layout the original harness to get the wire lengths correct, where the bends and clips, et. go and replace with new.... Got the correct wire, and maybe even weather proof connectors? Go for it.
I have used the Painless many times for Jeeps and Early Broncos. Very Painless and most wires are pre-terminated so they just plug right in.
Funny .. it has been nearly 2 months now since I last made any progress on the project. I was at the point of painting the under carriage parts .. of course everything is disassembled .. and had decided to go with Chassis Saver, tested it on a few pieces and hated the results - over the last two months I've learned more about POR products that I ever wanted to know - the problem was Chem-Pop, so spraying it on turned out to be the best application method for professional looking results .. which led to me trying to find a space to spray .. I have just finished refitting an unused 8 x 22' enclosed trailer into a small parts paint booth thanks to craigslist and a few found items .. see photos .. all said, I hope to be back in production this weekend painting parts and moving forward again!
As we test it with a dune buggy frame
Crossflow Hillbilly Engineering - forward door being used as an exhaust (picture is sideways)
my painless harness has been on the shelf for over 5 years... No plans on installing any time soon, my stock harness is fine and not a big pile of spaghetti... When I repaint the Jeep, I'll put the painless in.
Discovered my taillight harness at some point must have laid on the exhaust and melted some insulation. Is it possible to buy only that section of the harness?
