Full hardtop opinions
barrys
East Norriton
PA
Looking to hear feedback about YOUR experience with the various brands of full hardtops. I have 3 and am gonna sell one. I have an Acme, Aj's, and another one which may be a Grizzly, I am not sure. The back hatch looks almost identical to a fatory CJ-7 hatch. I have only driven with the Aj's, so I can't compare with the rest. neither of my CJ-8 are on the road, so I can't install the other 2 and get my own opinion.
Aj's, Ok quality, I don't like 2 latches on the hatch, windshield attachment is kinda lame
Acme, heavy, finished inside, nice attachment clips
Other? looks good, raw finish inside like Aj's
I reallly don't need opinions on any of the other tops as I won't be buying another since 3 is enough for 2 jeeps, 1 for sale.
I don't know the manufacturer of either of the hardtops I have had, but I do have pics. Both were unfinished on the inside other than paint. Both had lousy windshield frame attachment. But, the first one, the black one, looked like it used a stock CJ hatch, had huge windows, and the fit was awesome. The door openings were fully finished, and it had great visibility. Unfortunatley I sold it.
attachment.php
The top I have now, the brown one, has much poorer fit/finish. The door openings are rough cut and the capped with pinch molding, and the windows are smaller. And the rear hatch is FUNKY! Tiny window, reminds me of a real old Honda. However, with a 36" spare, uyou really don't loose any visibility. The lower edges where it mounts to the body are also a rougher cut style.
attachment.php
attachment.php
My advice- keep the one that fits the best.
i have an acme and i do like how it latches on and the look. but it is really heavy. oh and the visibility is pretty good. with only having my driverside mirror im always lookin around and can see pretty good
**IF** your third top is a Grizzly, I have only heard great things about them.
If I had to pick between the Acme and the AJ's I would pick the Acme. In fact, I traded an AJ's for an Acme (in slightly worse condition). I personally like the lines (never cared for the "bump up" on the AJ's. Also, there is about 4-6" more room in the Acme top (taller inside). I prefer the way it connects (flip catches as opposed to drilling the tub and using bolts). My son caught his leg on one of the angle brackets on the AJ's top because the brackets are wider than the lip they mount to (no damage...but I could see where someone could get cut). Also, where the AJ's top mounts to the windshield is a horrible design. I had to stuff that area full of insulation to eliminate wind noise. With the Acme top, just a thin strip of truck camper foam on the top seals it. Also, the door openings are much better designed and required considerably less work to fit well. A lot of small things that add up.
Other things to consider...the Acme top is heavier. I was able to remove my AJs top by myself. I needed help with the Acme. The Acme top is stronger (the AJs top bowed down in the middle...the Acme has not). Also, when I tried to put the Acme top on by myself, I lost control and it fell (from a height above the roll bar) and landed on one side. I thought for certain it would have shattered...but it was still perfect.
Regardless of the top you use, take the time to remove the windows, clean the seals, and re-install. Both hardtops I have used had so much gunk in the seals that they would leak inside...
